Go Back   CNCzone.com-The Largest Machinist Community on the net! > Events, Product Announcements and More > CNCzone Club House
CNCzone Club House Discuss everything in between CNC. THIS IS NOT A TRASH BIN.
Old 06-20-2008, 09:05 PM
ProDrawerCom
IQChallenged is on a distinguished road
LONG router bits
I cannot believe I can't find a spiral upcut router bit for machinable wax 2" thick. But I can't. The usual cutting length is about 1/2" or maybe 3/4". Anybody got any ideas? Thanks
Old 06-20-2008, 09:25 PM
ger21's Avatar
What diameter do you want?
Old 06-20-2008, 09:27 PM
ger21's Avatar
http://www.vortextool.com/standard/p...fm?groupID=330
http://www.vortextool.com/standard/p...fm?groupID=277
Old 06-20-2008, 09:54 PM
*Registered*
Mike Stevenson is on a distinguished road
.500" router bits come in 2.0" flute length as a standard length.
Old 06-21-2008, 08:48 AM
ProDrawerCom
Sizes
1/8" and 1/4". I'll check your posted links. Thanks
Old 06-21-2008, 08:55 AM
ProDrawerCom
Maybe I'm looking for something I don't need. I've always assumed it would be proper machining practice to use a flute length at least as long as the depth of the cut. Maybe it doesn't matter as long as the shaft size is no large than the flute diameter. Any comments?
(I'm a respiratory therapist trying to participate in a hobby requiring the skills of a machinist.)
Old 06-21-2008, 10:03 AM
*Registered*
Question 16:1 extension ratio?
You are going to be making 2" depths of cuts with a 1/8" cutter? Is there any way you could explain a little better exactly what your doing here?
Old 06-21-2008, 06:47 PM
ProDrawerCom
more info
Cutting some pockets in wax. On my current project I want to cut some pockets that are about 1-1/2" long, more than 1/8" wide but narrower than 3/16" wide, 1" deep. I haven't been able to find up-cut spiral router bits 1/8" in diameter with flutes more than about 1/2" (deep). By the time the collet eats up 1/3rd of the overall length you don't have much range at all. I've tried drywall cutters with some success but they're not really made for this and don't work optimally. I'm sure I'm not the first to want to cut some deep, narrow channels or vanes in wax. But I sure as hell can't find any long bits. I'd like to have some 1/8" and 1/4" bits with flutes about 1-1/2" and overall length about 3". I'm satisfied they're out there. Just can't find them.
Old 06-21-2008, 06:54 PM
ger21's Avatar
Good luck. I've never seen any that long. Vortex can custom make them for you. These are the longest tools I've ever seen, but they're for foam.
http://www.3dcutting.com/products-fr...imageId=image2
*Registered*
Of course their out there. I use them in metal cutting all the time but you kept saying what you wanted was "up-cut spiral" router bits in those lengths & sizes. Up-cut spiral router bits are made for WOOD. You can cut plastic with any type of cutter. Think metal working END MILLS not router bits and be free.
P.S. This company will grind any tool. any size that you need.
http://swifttool.dirxion.com/entryma...en=1280&os=win
  #11   Ban this user!
Old 06-21-2008, 07:03 PM
ProDrawerCom
Response
Well I said up-cut router bit because they work really well. But I knew all along that an end mill would be fine too. But I can't find them either. Turn me on to a site for those and I'll dance at your next wedding. The Frog bits that GER linked me too look really beautiful but they don't list any small enough.
Old 06-21-2008, 07:09 PM
*Registered*
Swift
OSG
Niagra
SGS
SCT
Marshall Tool
EF Bailey Co
MSC Industrial Supply
more?
Extra long router bits for foam xshaper Product Announcements & Manufacturer News 0 10-14-2007 12:45 AM
Looking for long router bits Hack WoodWorking 3 08-09-2005 03:14 PM
Extra long router bits whiteriver General Material Machining Solutions 11 06-06-2005 03:21 PM
Where to order Router Bits, long, complete ?? Calico WoodWorking 0 05-01-2005 02:10 AM
looking for Long router bits supplier in UK. MrBean DIY-CNC Router Table Machines 2 10-11-2004 06:36 PM
