| CNCzone Club House Discuss everything in between CNC. THIS IS NOT A TRASH BIN. |
| Hello folks. I'm new to this forum and looking for some help. I have 15 years experience using Fanuc controls but have not touched a CNC control in about 8 years now. I have been given the task of programming a production machining job on an Okuma MC-4VA with an OSP5000M-G control. I have everything doing what I need to do in my main program. What is kicking my tail is calling a sub-program from within my main program. ALL help and suggestions is greatly appreciated. |
I believe the formatting is the same for a Mill. Could find a mill sample, but found this. (************ VARIABLE SET ****************) V1 = .236 (A DIM BOTTOM OF CONDYLE TO FACE) V2 = 2.300 (OVERALL HGT. OF PART ACTUAL ) V3 = 3.500 (DIA. OF PART DURING TURN ) V7 = 65 (SIZE IN MM. ) (*****************************************) V5 = V1+.720+1.250 (*****************************************) G50 S1500 (TURN) NLAP1 G81 N070 G0 G42 X-.030 Z=V2+.05 N080 G1 Z=V5 F.003 N090 G1 X.292 Z=V5 N100 G1 X.3695 Z=[V5-.040] N110 G1 X.3695 Z=[V5-.2516] N120 G2 X.3758 Z=[V5-.2733] L.125 N125 G1 X.6960 Z=[V5-1.1814] N130 G2 X.8594 Z=[V5-1.2500] L.083 N140 G1 X=V3 N150 G0 X=V3+.100 G40 G80 N160 G97 G95 G0 X21 Z10 T101010 S1500 F.006 M3 M42 N170 G0 X=V3+.100 Z=[V2+.100] N180 G85 NLAP1 D.200 U.010 W.002 F.006 N190 G0 X=V3+.100 Z=[V2+.100] N200 G87 NLAP1 N210 G0 X21 Z10 M5 M00 (CHECK TAPER) N220 M110 N230 G00 C0 M16 N240 G00 X4.3628 Z=[V5+.500] T080808 SB=1750 M13 N250 G90 G94 N260 G137 N270 G17 IF [V7 EQ 55] NTP55 IF [V7 EQ 60] NTP60 IF [V7 EQ 65] NTP65 IF [V7 EQ 70] NTP70 IF [V7 EQ 75] NTP75 GOTO N410 NTP55 CALL OSUBE GOTO N410 NTP60 CALL OSUBA GOTO N410 NTP65 CALL OSUBB GOTO N410 NTP70 CALL OSUBC GOTO N410 NTP75 CALL OSUBD N410 G00 Z=[V5+.500] N420 M12 N430 G136 N450 M109 N460 G00 X20 Z20 M5 M2 (**************) OSUBA (60MM CHAMFER) N280 G00 X-2.5000 Y-.9500 N290 G00 Z=[V5-1.25+.050] N300 G01 Z=[V5-1.25-.05] F10. N310 G101G41 X-1.2001 Y-.9500 F10. N320 G101 X-1.2001 Y-.4171 N330 G102 X-1.1294 Y-.1413 L.5730 N340 G102 X1.1292 Y-.1413 L1.2884 N350 G102 X1.2000 Y-.4171 L.5730 N360 G101 X1.2000 Y-.6416 N370 G102 X.6067 Y-.9272 L.3654 N375 G103 X-0.6069 Y-.9272 L.9730 N380 G102 X-1.2001 Y-.6416 L.3654 N390 G101 X-1.2001 Y.9500 N400 G00G40 Z=[V5+.5] RTS OSUBB (65MM CHAMFER) N280 G00 X-1.9938 Y-.9500 N290 G00 Z=[V5-1.25+.050] N300 G01 Z=[V5-1.25-.05] F10. N310 G101G41 X-1.2938 Y-.9500 F10. N320 G101 Y-.4335 N330 G102 X-1.2085 Y-.1182 L.625 N340 G102 X1.2085 Y-.1182 L1.400 N350 G102 X1.2938 Y-.4335 L.625 N360 G101 Y-.6950 N365 G102 X.6473 Y-1.0100 L.400 N370 G103 X-.6473 Y-1.0100 L1.050 N380 G102 X-1.2938 Y-.6950 L.400 N390 G101 Y-.250 N400 G00G40 Z=[V5+.5] RTS OSUBC (70MM CHAMFER) N280 G00 X-2.1814 Y-.9500 N290 G00 Z=[V5-1.25+.050] N300 G01 Z=[V5-1.25-.05] F10. N310 G101G41 X-1.3876 Y-.9500 F10. N320 G101 X-1.3876 Y-.4509 N330 G102 X-1.2870 Y-.0959 L.6769 N340 G102 X1.2870 Y-.0959 L1.5115 N350 G102 X1.3876 Y-.4508 L.6769 N360 G101 X1.3876 Y-.7485 N330 G102 X.6877 Y-1.0928 L.435 N340 G103 X-.6877 Y-1.0928 L1.127 N350 G102 X-1.3876 Y-.7485 L.435 N395 G101 X-1.3876 Y.9500 N400 G00G40 Z=[V5+.5] RTS OSUBD (75MM CHAMFER) N280 G00 X-2.1814 Y-.9500 N290 G00 Z=[V5-1.25+.050] N295 G01 Z=[V5-1.25-.05] F10. N300 G101G41 X-1.4814 Y-.9500 F10. N310 G101 X-1.4814 Y-.4688 N320 G102 X-1.3659 Y-.0751 L0.7288 N330 G102 X1.3659 Y-.0751 L1.6231 N340 G102 X1.4814 Y-.4688 L0.7288 N350 G101 X1.4814 Y-.8004 N360 G102 X.7274 Y-1.1749 L0.4700 N370 G103 X-.7274 Y-1.1749 L1.2038 N380 G102 X-1.4814 Y-0.8004 L0.4700 N390 G101 Y-.125 N400 G00G40 Z=[V5+.5] RTS OSUBE (55MM CHAMFER) N280 G00 X-2.1000 Y-.9500 N290 G00 Z=[V5-1.25+.050] N295 G01 Z=[V5-1.25-.05] F10. N300 G101G41 X-1.1063 Y-.9500 F10. N310 G101 X-1.1063 Y-.4021 N320 G102 X-1.0502 Y-.1669 L.5212 N330 G102 X1.0502 Y-.1669 L1.1769 N340 G102 X1.1063 Y-.4021 L.5212 N350 G101 X1.1063 Y-.5881 N360 G102 X0.5665 Y-.8444 L.3308 N370 G103 X-0.5665 Y-.8444 L.8962 N380 G102 X-1.1063 Y-.5881 L.3308 N390 G101 X-1.1063 Y.9500 N400 G00G40 Z=[V5+.5] RTS % |
| Thanks Mongo, This is what I have: Code: N4 G15 H10 N8 S750 M3 N10 /M8 N12 GO X0 Y0 N14 G56 Z0.1 H10 N16 CALL OSUBA I originally had a numeric subprogram name but cghanged it to SUBA.SUB after receiving your reply butr I'm still getting the same alarms. Is this the correct extension for subprograms? I have RTS at the end of my subprogram. is this correct? Thanks again for your help. |
Hope this helps. Oti |
| Needing help please | Larry Myers | G-Code Programing | 4 | 10-04-2007 02:22 PM |
| needing some imput | sodickappsguy | CNC Plasma and Waterjet Machines | 3 | 07-30-2007 09:57 PM |
| New guy needing help please... | studysession | Welding, Brazing, Soldering, Sealing | 17 | 01-12-2007 01:18 PM |
| needing an opinion | CNC Mendez | CamSoft Products | 1 | 07-21-2006 04:34 PM |
| New guy needing recommendations | jlh28 | General CAM Discussion | 3 | 01-13-2006 09:05 PM |
