Go Back   CNCzone.com-The Largest Machinist Community on the net! > Events, Product Announcements and More > CNCzone Club House
CNCzone Club House Discuss everything in between CNC. THIS IS NOT A TRASH BIN.
Old 02-09-2008, 11:39 AM
SES1 is on a distinguished road
How to machine ends of THK type linear rail
I have purchased some surplus linear rail that is all cut to the same length.
Does anyone have experience in machining the ends of THK type linear rail to mate?
Thanks for your help.
Old 02-20-2008, 07:20 AM
Mr_bossman is on a distinguished road
Lightbulb
One thing to remember is these rails are very hard material.One way is to use a quick cut saw,another is EDM wire them or grind on a surface grinder.
Hope this helps.....
Old 02-20-2008, 07:31 AM
LeeWay's Avatar
LeeWay is on a distinguished road
I burned up one bandsaw blade and three diamond wheels on a dremel making one cut. Then dressed both ends on a belt sander. The end result was fine, but took about an hour to slice through. Chop saw is on my list of things to buy. I have one for wood, but they really aren't made for metals other than aluminum possibly with the right blade.
Lee
Old 02-20-2008, 07:40 AM
Thanks for the response Mr Bossman and LeeWay. These rails are hard for sure. We've been able to cut them with a chop saw ( using coolant also) and machine the ends with a carbide mill, but we aren't sure about the edges and tolerances. My guess is the factory bevels the edges somewhat to eliminate burrs. We stoned the edges slightly, but there is still a slight resistance when the bearing makes the transistion between rails. Maybe the seal is catching, not sure at this point.
Is it possible to machine Ballscrew ends 7x lathe Toymanf Mini Lathe 15 07-29-2007 08:22 AM
Linear rail alignment Dom B Linear and Rotary Motion 14 10-04-2006 04:45 PM
single linear rail? erase42 Linear and Rotary Motion 3 01-22-2006 01:36 PM
What type of steel for linear shafts can I machine? cbcnc DIY-CNC Router Table Machines 0 04-14-2004 12:57 AM
