Go Back   CNCzone.com-The Largest Machinist Community on the net! > Events, Product Announcements and More > CNCzone Club House
CNCzone Club House Discuss everything in between CNC. THIS IS NOT A TRASH BIN.
Old 12-25-2007, 03:12 PM
jstrayer is on a distinguished road
Convert 440 3ph to 220 3ph
I've come across a cold saw for a good price I would like to buy. How much trouble and expense would it take to convert it form 440 3ph to 220?
Thanks,
JStrayer
Old 12-27-2007, 09:07 PM
AJKovacs is on a distinguished road
The simple way would be to use a VFD (variable frequency drive). If you spec the correct drive you can put any voltage in and get any voltage out. Just make certain the drive is large enough to provide the amps you need.
Old 12-27-2007, 10:44 PM
Al_The_Man's Avatar
Have you checked as to whether it is a dual voltage motor? If so it is just a question of changing the terminal connections to suit.
How to convert DXF to PLT Kristjan General CAM Discussion 1 07-17-2007 06:08 PM
Convert from JPG to DXF chakaloso General Metal Working Machines 4 03-10-2007 03:31 AM
Convert cc to hp ? diarmaid Calibration & Measurement 31 08-27-2006 05:47 PM
How did you convert CNCadmin Benchtop Machines 5 03-18-2003 10:42 AM
