Go Back   CNCzone.com-The Largest Machinist Community on the net! > Events, Product Announcements and More > CNCzone Club House
CNCzone Club House Discuss everything in between CNC. THIS IS NOT A TRASH BIN.
Old 12-19-2007, 02:41 PM
Buzz239 is on a distinguished road
Question about engraving Radio Dials
I'm kind of in a quandary. I need to engrave, chemically etch or laser cut three types of radio dials. These dials (see attached) are not made any more and when you find them everyone wants a premium price for them. The dials were originally made by National Radio, who is now defunct. I can cut the blanks and when finished I can drill the appropriate mounting holes and fill the lettering. I guess the question is; what's the least expensive method to go with? I need a run of 100 each. Any help would be appreciated.
TNX, Buzz
Old 12-19-2007, 03:13 PM
One of Many is on a distinguished road
You could make your own custom stamp and press these markings.
Numberall has an array of options for the number blocks which are not to badly priced. There are other steel stamp outfits that will do custom stamping blocks out of solid.
I have yet to see any software that would do this type of stamping die, but I'd imagine a decent cam package could handle it with a bit of finese.
DC
Learn cause and effect through experience. Mastering those relationships is the "Common Sense" ability within the art of any trade.
Old 12-20-2007, 03:12 AM
neilw20's Avatar
neilw20 is on a distinguished road
Question Easy as..
A correctly shaped engraving tool will have no problem making these dials.
Machining time may be acceptable, depending on the target price.
Mount them on a centre hub. Hold them down securely. You can make these on a CNC. If put into a CAM program, machining time can be estimated readily.
Super X3. 3600rpm. Two possible way to fix things: The right way or the other way.
Need help on how to engrave steel sight dials VAAR Engraving Machines 5 12-07-2007 07:15 AM
[PICTURES] Milled out a circle using only dials and laptop ichudov Bridgeport and Hardinge Mills 11 06-14-2007 09:24 AM
Zeroing the dials? wildcat Industrial Hobbies (Support forum) 2 11-17-2006 06:53 PM
Engraving clock dials Thurbo CNCzone Club House 4 03-21-2006 06:42 PM
Radio Shack Switch Question. ljoe1969 General Electronics Discussion 2 06-02-2004 03:28 PM
