Go Back   CNCzone.com-The Largest Machinist Community on the net! > Events, Product Announcements and More > CNCzone Club House
CNCzone Club House Discuss everything in between CNC. THIS IS NOT A TRASH BIN.
Old 11-25-2007, 06:42 PM
pizzaman is on a distinguished road
Question mineral cuting oil or water soluables for cnc?
My new little sharp cnc does more sitting then being used at the moment and the standard coolant seems to need alot of maintainence. Hate that smell too. Is their a problem with using pure mineral cuting oil as a coolant? Does it act as a good lubracant as well and keep the machine clean?. I'll be cutting mostly aluminium, and some mild steel. I now it would cost more but wouldn't it last longer.? what are the main reasons not to use it? I know they use pure oil in the carbide grinding industry and it sure kept the machines cleaner then the water base. Just woundering the pros and cons. Thanks
Water cut?? Yepez CNC Plasma and Waterjet Machines 8 02-24-2010 09:23 AM
Who has a water jet? fastolds Employment Opportunity 3 10-22-2007 10:13 PM
Water transfer techniques for water table? Knut CNC Plasma and Waterjet Machines 3 02-02-2007 10:52 AM
looking for water jet in LA the4thseal Employment Opportunity 7 11-14-2005 07:58 AM
portal milling machine - construction - mineral casting fidibus42 Mechanical Calculations/Engineering Design 0 10-23-2005 11:00 AM
