Go Back   CNCzone.com-The Largest Machinist Community on the net! > Events, Product Announcements and More > CNCzone Club House
CNCzone Club House Discuss everything in between CNC. THIS IS NOT A TRASH BIN.
Old 10-24-2007, 07:09 PM
PoiToi is on a distinguished road
Best way to lock a nut to a bolt?
Hello all, i have a simple question (at least for some of you i'm sure =) ).
What is the best way to lock a nut on a bolt? I know 2 nuts tightened together works well, but I was wondering if there was any better way to do it..I 've noticed that sometimes with that method you can still turn the nuts together by just turning one.
The bolt will be subjected to high heat (500+ F) so a nylon nut is definately not the answer. I know they sell high heat loc-tite but I want to be able to take it apart when i need to.
Old 10-24-2007, 07:49 PM
Mcgyver is on a distinguished road
check loctite's site, iirc even the high temp loctite still comes apart with heat, its just effective at a higher temp. I know i've use their 620 high temp retaining compound and it comes apart with heat (obviously more than the temps its intended to be good for) but double check the high temp thread locker
Old 10-24-2007, 08:14 PM
Use a castellated nut and put a split pin through a hole in the bolt.
If the bolt and nut is big enough put a diametral saw cut 3/4 of the way through the nut then drill and tap for a small bolt to pinch this cut and lock the nut against the threads.
Old 10-24-2007, 08:42 PM
MrWild is on a distinguished road
The absolute cheapest yet sure fire locking nut is to take a standard nut and give it a squeaze in the vice. You will have to experiment a little how much squeaze to do, but these work VERY well. This is the some principal as the lock nuts with the center punched dimple on one facet. Both deform the nut causing it to squeaze on the threads.
Old 10-24-2007, 10:10 PM
mxtras's Avatar
Silver Member
mxtras is on a distinguished road
You could use an all metal locknut, but they are not my favorite.
The best method might be to use safety wire.
Scott
Consistency is a good thing....unless you're consistently an idiot.
Old 10-25-2007, 08:11 PM
Talking
Mr Wild, do you mean squeeze the not after it's threaded on? or before and then put it on with some force?
either way might work.
geof, i really like that idea!
i dunno if the nut is big enough, if nothing else i think i can manage to make something here at work!
Old 10-26-2007, 04:10 AM
dertsap's Avatar
Gold Member
dertsap is on a distinguished road
you can buy solid steel lock nuts , cheap and effective ,
http://www.fastenal.com/web/products...l.ex?sku=37278
Old 10-26-2007, 09:21 AM
mxtras's Avatar
Silver Member
No love for the safety wire idea, huh?
Old 10-26-2007, 12:47 PM
JROM is on a distinguished road
In the airplane and race car biz. if you don't want it to come loose you use safety wire.
It's an elegant fix and it looks sexy.
Be carefull what you wish for, you might get it.
Old 10-26-2007, 01:32 PM
Andre' B is on a distinguished road
One of these works great for the locking part.
http://en.wikipedia.org/wiki/Ball-peen_hammer
Add one of these for the removal part.
http://en.wikipedia.org/wiki/Chisel#Cold_chisel
  #11   Ban this user!
Old 10-26-2007, 01:54 PM
I did think of suggesting the Arc Welder/Sawzall combination for fixing and removing; I am partial to power tools not hand tools.
  #12   Ban this user!
Old 10-28-2007, 09:15 PM
RickWG is on a distinguished road
Zap it with the MIG
Home Build Water Jet - Pressure Washer 1ctoolfool CNC Plasma and Waterjet Machines 20 12-20-2011 09:06 AM
Seal/Washer In UNIVER Valve Type AE 1001 Replacement On Bridgeport Help!! Huntersyv Bridgeport and Hardinge Mills 1 02-07-2006 02:02 PM
Possible OT: Fab Aluminum washer kellogs72 General Metalwork Discussion 6 01-25-2005 09:09 PM
Glueing bolts in...Liquid lock-washer? samualt DIY-CNC Router Table Machines 3 10-04-2004 12:32 PM
spring washer question sendkeys General Metal Working Machines 2 07-12-2004 03:38 AM
