Results 1 to 5 of 5
Thread: Okuma IGF Programing
    Oct 2007
    U.S.
    It's been quite some time since I used IGF on Okumas. What I'm having trouble with is going from a straight cut to a radius or angle that leads to a radius or angle. It seems I get an error message all the time. Help!
    Registered Jarwalcot's Avatar
    Jun 2005
    Leave the "Z" end point empty...
    Good luck,
    JR Walcott
    Georgia Machine Tool Resources, LLC
    Dec 2007
    Argentina
    hola! soy de argentina, estoy buscando el software igf del okuma osp 5020l solo para poder instalarlo en mi computadora y sacarle mas provecho del q le saco en mi trabajo ya q estoy aprendiendo, desde ya agradecido con cualquier ayuda...
    Jun 2005
    I'm working off memory here... Try not inputting an end point. IGF will calculate that for you as long as you have the radius called out. If it doesn't, check your IGF parameter's.
    Let us know how things turn out.
    JR Walcott
    Jul 2010
    When using IGF Make sure the cutter comp is set rite.If you have a .030 rad. in the corner the machine will alarm telling you tool nose radius is wring in nrc.So turn your part whithout programing the .030 radius in that corner.This only applies to fillet radius that is smaller then the radius on the tool. When you finish your profile with a .015nose radius you can insert the.030 radius with that tool. thanks ,
    Hope that helps Rich
    1. okuma lathe programing software help
      By ironmike2682 in forum General Metal Working Machines
      Last Post: 02-13-2013, 08:58 PM
    2. Help on programing the PIC in MM2001
      By DreamerM in forum PIC Programing / Design
      Last Post: 08-29-2011, 08:56 PM
    3. Thanks for all the help! but now I have questions on programing
      By rcbamm in forum DIY CNC Router Table Machines
      Last Post: 05-28-2007, 08:32 AM
    4. Programing AUX buttons
      By George C in forum AjaxCNC Control Products
      Last Post: 02-10-2007, 02:33 PM
    5. CAM programing
      By kenlambert in forum G-Code Programing
      Last Post: 02-03-2006, 01:03 AM
