| CNCzone Club House Discuss everything in between CNC. THIS IS NOT A TRASH BIN. |
| I have an Ikegai tcr15 with ot controls....can power machine up, home it out, all controls work, rapid travels, turret indexing, can write program, but when hit cycle start nothing happens...does not give alarm.....can anybody help me find out what is wrong?? Thanks |
| The system may sometimes seem to be at a halt, although no alarm is displayed. In this case, the system may be performing some processing. The state of the system can be checked using the self-diagnostic function. - Diagnostic Screen, #Diag 700, 701, and 712 |
| Start simple: - Check for proper air pressure (if needed) - Check all fluid levels - Check the state of spindle chuck (open/close) and proper setting of OD or ID operation - Check all door interlocks are made - Check status of barfeed (if applicable) - Cycle tailstock forward/back, quill in/out (if applicable) - Confirm that diagnostics 700, 701, and 712 are all zero's when trying to start |
I hAVE THE SAME MACHINE AND HAD THE SAME PROBLEM. WHEN YOU PUSH CYCLE START DOES THE (GREEN)CYCLE START LIGHT COME ON AND DOES THE CYCLE TIMER RUN. IF SO YOUR MACHINE IS WAITNG FOR A SPINDEL ARRIVAL SIGNAL TO RUN. BUT THE THE SPINDEL DRIVE NEEDS TO BE TUNED FOR THE X AND Z AXIS BEFORE THE MACHINE WILL RUN. tO CHECK THIS LOOK AT DIAG 800-801-802-803 THEY SHOULD BE 0 + OR - 2. MINE WAS + 23 FOR THE X AND -17 FOR THE Z YOU NEED TO ADJUST THE SPINDLE DRIVE SCREWS TO BRING THEM CORRECT READING IF YOU NEED HELP WITH THAT LET ME KNOW RON |
Dear all. I have the same machine and the same problem. All dignosic #700, 701 and 712 are all 0. When I depress CycleStart button, the CycleStart LED is not lit, and nothing happen. I already check about chuck, barfeeder, tailstock...( as bborb recomended, thanks bborb), but seem like nothing goes wrong there. pls. help me to fix this problem. Thanks. |
Dear Sir, I recently import Ikegai TCR-15 CNC Lathe with fanuc 18T-A year of Manufacture 1995 from UK. We power up the machine & came to know that unfortunately machine had Ram parity error. Only few pages of parameters are with the machine. Some how we start the machine with the help of few pages. Now machine is working but only one function is not enable(Feed per Revolution). Encoder cable is OK. Please help us in this regard. Will be happy to hear from you. Best Regards, Mian |
| Dear Sir, I recently import Ikegai TCR-15 CNC Lathe with fanuc 18T-A year of Manufacture 1995 from you. We power up the machine & came to know that unfortunately machine had Ram parity error. Only few pages of parameters are with the machine. Some how we start the machine with the help of few pages. Now machine is working but only one function is not enable(Feed per Revolution). Encoder cable is OK. Please help us in this regard. |
| Ikegai AX20Z CNC Lathe trouble | motter71 | General Metal Working Machines | 3 | 07-27-2009 05:49 AM |
| Help! Ikegai FX-20N and Fanuc 5T problem! | Radius | General Metal Working Machines | 2 | 05-29-2009 12:42 PM |
| Ikegai FX20N lathe | gridley51 | General Metal Working Machines | 9 | 11-17-2007 07:19 PM |
| Ikegai TV-4 machine M06 not working. | Ashu | CNC Machining Centers | 23 | 09-26-2007 10:47 AM |
| How much does an Ikegai FT20U weigh? | protrxrptr17 | General Metal Working Machines | 1 | 12-13-2006 08:39 PM |
