| CNCzone Club House Discuss everything in between CNC. THIS IS NOT A TRASH BIN. |
Any one know of a place that might sell a 3/8 case hardened and ground shaft with a center hole all the way through about 4" long? The hole can be small if some thing like that is even available. Thanks Dennis
__________________ Dennis |
| Dennis check www.nbcorporation.com under SNT "pipe shafts" They have 6mm to 100mm od with 2mm to 60mm id hardened slide shafting.
__________________ DZASTR Last edited by RICHARD ZASTROW; 09-06-2007 at 03:13 PM. Reason: add: |
| Also check out Misumi, they have tubular shafting in different materials, also they have started including Imperial as well as Metric sizes. Al.
Thanks for the tip Al. I got some 3/8 x 4" ground shafts with center hole from Misumi for $6.50.
| pierce for center of hole | bearracecars | CNC Plasma and Waterjet Machines | 2 | 08-31-2007 10:46 PM |
| finding center of a hole | BeerFizz | Mach Mill | 1 | 06-14-2007 07:17 PM |
| Finding the center | Tazzer | General Metalwork Discussion | 6 | 08-05-2006 12:18 PM |
| Drilling a hole in the center of a bolt / newby question | stickben | Mechanical Calculations/Engineering Design | 1 | 04-30-2006 11:07 AM |
| what to do with center tap? | truman | General Electronics Discussion | 21 | 01-20-2006 10:21 PM |
