Go Back   CNCzone.com-The Largest Machinist Community on the net! > Events, Product Announcements and More > CNCzone Club House
CNCzone Club House Discuss everything in between CNC. THIS IS NOT A TRASH BIN.
Old 08-08-2007, 04:03 PM
John Teichman is on a distinguished road
Smile z axes problem
I have a fairley new machine 4x3 table built very heavy all my 2d cutting goes ok. i use vcarve soft. i also do 3d carving and the shorter files seem to run good most of the time but as i increase the length of files the z axes wants to pick up about 1/3 of the way into the file i seem to have a heating problem so i added better heat sink and another fan to cool drives i think i have older gecko drives and am running mach 2 i thought i cooled the drives enough but problem still there i am new to cnc so somewhat lost , builder of machine is very helpfull and is replaceing heatsink w/ newer style drives and maybe up grade to mach 3 i wonder if i could be missing somethin or causing the problem? any ideals . thanks for looking John.
Old 08-12-2007, 09:14 AM
Ole Klepp is on a distinguished road
I have just the same problem . using V.Carve soft and Flash cut.The problem seems to be the configuration in the Flash cut program.The federate and ramping values was sett to high. I will test it out tomorrow.
regards
Ole Klepp
Old 08-14-2007, 06:40 AM
z axes
Hi Ole Klepp thanks for responding did the new settings help any or did you try them yet?? John.
Wierd z axes problem jonmessenger TurboCNC 0 03-01-2007 03:49 PM
can't jog axes BobM3 Fanuc 2 10-23-2006 04:00 PM
Can I run axes at different ipm on the same pass? yorttroy DIY-CNC Router Table Machines 5 01-04-2006 12:34 PM
4 Axes GOBUS DIY-CNC Router Table Machines 0 12-07-2005 07:29 AM
can anyone explane all 8 axes? zander1 General CAM Discussion 11 07-08-2004 10:50 AM
