Go Back   CNCzone.com-The Largest Machinist Community on the net! > Events, Product Announcements and More > CNCzone Club House
CNCzone Club House Discuss everything in between CNC. THIS IS NOT A TRASH BIN.
Old 08-06-2007, 07:49 PM
bearman22 is on a distinguished road
Cool Haas helical motion
Hello everyone,
I would like to know how to perform a helical motion on a Haas VF4 mill. Im cutting out a 3" dia. hole to a 4" and going down about 5". I will be using a new Iscar 2" mill that is about 7" long from the tool holder base. Could someone help?
Bear
Old 08-06-2007, 09:32 PM
HuFlungDung's Avatar
Moderator
Check the Haas website for information. In this online manual, the 70th scanned page describes thread milling. You can adopt this same programming method for helical interpolation to open up a hole.
http://www.haascnc.com/training/Mill...m_PDF/xmwb.pdf
Old 08-06-2007, 09:35 PM
You add a Z motion to a normal G02 or G03.
You will probably be using G03 because you are inside a hole. You can do the entire helical operation from a single command. I don't know how much Z feed your machine and tool can handle so the numbers here may not apply but they demonstrate the idea;
I am using the hole center as the work zero.
You position the tool say 0.05" above the work piece and at the correct radius.
From this point you want to go down 5.05 and for this example I will assume your tool can handle a 0.5" DOC, in other word each time around the circle Z advances 0.5". Dividing 5.05 by 0.5 gives 10.1 so it is easier to make the DOC 0.505 for an even 10 circles.
On the Haas G03 using I and J works exactly the same in incremental as in absolute so your program will be something like;
G90 G00 X0. Y1. Z0.05 (Positions at start)
G91 G03 I0. J-1. Z-0.505 F(whatever) L10 (This does 10 circles and moves Z-5.05)
G90 G03 I0. J-1. F(whatever) L1 (This does one circle to clean up the bottom)
G00 X0. Y0. Z1.0 (This returns to the center and lifts clear)
Old 08-07-2007, 05:15 PM
Thanks GEOF!
Old 08-11-2007, 05:03 PM
CAMCRASH is on a distinguished road
To Keep The Program Small You Could Use The
M97 (internal Sub ) P ( Internal Line # ) & Loop
Then Create A Small Incremental Sub Program After The M30
This Will Keep Lines & Memory Space To A Minimum
IF I ONLY WOULD HAVE FINISHED READING THE PREVIOUS POST
IT SAYS ALMOST THE SAME WITH JUST A LITTLE TWIST
I LIKE TO USE THE M97 WHEN SWITCHING BACK & FORTH FROM ABS TO INC
GUYS ON SHOP FLOOR SEEM TO PICK THESE DETAILS OUT BETTER FOR SOME REASON
Helical Milling binzer GibbsCAM 3 03-30-2007 04:39 PM
Helical Gear M-man General Metalwork Discussion 11 10-17-2006 03:06 PM
Helical milling with HAAS dinger G-Code Programing 10 06-19-2006 01:36 AM
G2/g3 Helical In Yz(g19) leggetmachine G-Code Programing 4 03-22-2006 10:48 PM
Helical Interpolation dbcoop11 Bridgeport and Hardinge Mills 4 12-31-2004 10:15 AM
