Go Back   CNCzone.com-The Largest Machinist Community on the net! > Events, Product Announcements and More > CNCzone Club House
CNCzone Club House Discuss everything in between CNC. THIS IS NOT A TRASH BIN.
Old 05-13-2007, 01:14 PM
tybrenis's Avatar
tybrenis is on a distinguished road
Hack a lightscribe into a CNC laser?
Hey guys,
I was just taking a look at those new lightscribe DVD/CD burners, the ones that use a small laser to burn an image onto a disk. Could the laser in one of those be added onto a CNC router or similar and used to do lightweight engraving sort of work?
Old 05-13-2007, 09:48 PM
paulC is on a distinguished road
The laser is too low in power to engrave anything.
You need about 8 watts to cut paper.
Paul
Old 05-14-2007, 04:46 AM
tybrenis's Avatar
Ahh, I see. Just out of curiosity, what type of laser does it use to engrave the disks? I don't know anything about the process used in lightscribe.
Old 05-14-2007, 03:23 PM
The disks have a special coating and I think the laser is causing a chemical change to the ink embedded in it. I'm not sure of the power of the laser but I would think it is less than half a watt.
Paul
Converting a laser printer into a 3d laser printer Joćo Carimo General Metal Working Machines 22 03-08-2012 10:21 AM
Why buy a Laser cutter when you can modify a laser engraver. spacifique1 Laser Engraving & Cutting Machines 7 08-13-2007 02:39 PM
Is this laser big enough?.. :) hotponyshoes Laser Engraving & Cutting Machines 8 03-28-2007 02:04 PM
HP Laser Jet II/III - RPM? Rance DIY-CNC Router Table Machines 2 01-10-2007 06:20 AM
Laser in x3? replicapro Laser Engraving & Cutting Machines 5 12-22-2006 12:20 PM
