I used 267 OzIn motors on mine on both axis and they work fine. Could be a bit faster, but get the job done. If the 111inoz motors you have a standard Nema 23 and have a standard 6mm or 1/4" shaft, you could use them to get started, and easily replace them if they are too slow in practice.
In the overallscope of a building and tooling up a lathe, the $45 each for two 300 ozin motors is peanuts.
LinkBack URL
About LinkBacks
