Page 1 of 4 1234 LastLast
Results 1 to 12 of 48
Thread: PVC Compressed Air lines
    Feb 2007
    Anyone here using PVC pipe for their compressed air lines and if so how does it work? Copper is so expensive these days and steel always rusts inside.I just bought a building and will be moving in soon. It isn't plumbed for air. I have a 40hp screw compressor with a backup 30hp screw feeding 5 cnc machines.
    Jul 2005
    No emphatically not!!!!!
    Apart from causing heart attacks to any safety inspectors that come by it is far too dangerous.
    When PVC fails under pressure it goes with a real bang and cracks propagate through the lengths of pipe very fast. You have a very good chance of filling your place with PVC shrapnel moving very fast.
    There are no simple plastics that are safe for compressed gases. If you wanted to use a carbon fiber reinforced composite that might work..at many times the price of copper.
    Use copper or galvanized. You should have a dryer on your compressor for CNC machines so with this there should be no water in the air to rust galvanized.
    Aug 2003
    DON'T EVER USE PVC FOR AIR LINES! Geof is right, pvc and air is like vineger and oil.
    If you don't believe me go to any of the plastic fitting company's web sites(Nibco, Lasco, Spears, Mueller ect)they all say "DON'T USE ON COMPRESSED AIR/GASES" I worked in the plumbing industry for years and none of the manufactures approve of its use on any compressed gases.
    If you want to see plastic fail, put a foot or two of pvc in your freezer for a couple of hours then drop it on the floor. It will shatter just like glass.
    Please note, that this applies to hard plastic that is glue or threaded together.
    If you really want plastic, look into flexiable plastic tubing(like the brake lines on semi-trucks) I myself use copper in my shop.
    Please read the following link
    http://www.spears.com/tech_updates/T...No.106_web.pdf
    http://www.spears.com/prod_dimension..._0206.indd.pdf
    http://www.lascofittings.com/support...pressedAir.asp
    JEFFY
    Gold Member
    Oct 2005
    PVC is unsafe and illegal to use for air lines.
    The key is as Geof stated, the explosive (not combustion, but rapid expansion) nature of compressed gases. PVC is rated to high pressure for liquids because liquids under pressure are not compressible. If you have a crack in a water line, you'll get a fountain which is annoying but not dangerous. The same crack in a PVC air line will cause the plastic to splinter and shatter because once vented, the compressed gas keeps trying to expand.
    Jan 2005
    Five-10
    There is a plastic pipe you can use it is Duraplus ABS Airline Pipe it is
    OSHA aproved and you can get it from ( IPEX ) This is designed for compressed gases this will not shatter like PVC can
    Mactec54
    Jul 2005
    Five-10
    I stand corrected, Thank You.
    I checked and found the Duraplus is rated at 185psi up to 73F and they also have a Duratec that is rated 160psi at 140F.
    Now all I have to do is find a supplier and see how the price compares to copper or galvanized. It should certainly be easier to install.
    The IPEX website does say it is a new product; I wonder how new.
    Moderator tobyaxis's Avatar
    Jan 2006
    Quote Originally Posted by Five-10 View Post
    No Way!!!!!!!! I saw some JackA$$ do this in a shop and while a co-worker was next to one of the lines it exploded. He is deaf in one ear now. Not to mention the scars on his face and ear.
    Never Ever Do This!!!!!!!!!! The Dangers are far too great to take the cheap way out.
    That new product might work better but never use PVC.
    Toby D.
    "Imagination and Memory are but one thing, but for divers considerations have divers names"
    Schwarzwald
    www.refractotech.com
    Jul 2005
    I should make it clear; this is the only sentence I stand corrected on:
    "There are no simple plastics that are safe for compressed gases."
    Jan 2006
    Quote Originally Posted by Geof View Post
    Sorry my post was windy. Yours is simple and to the point.
    BTW: your up too 3000 posts.
    Toby D.
    Schwarzwald
    Jul 2005
    Quote Originally Posted by tobyaxis View Post
    And you say you are the windy one; you are an amateur when it comes to windy.
    Jan 2006
    Well, unfortunately I lack experience and age LOL. I won't ever catch up to you but some day be as windy as you are now LOL.
    Cheers!!!!!
    Attached Thumbnails Attached Thumbnails PVC Compressed Air lines-dangerous_gasses.jpg
    Toby D.
    Schwarzwald
    Feb 2007
    OK, I decided to go Copper. Max Machine cuts no corners machining so I'm not going to start cutting corners with my new building. By the way my Haas service tech is the one that mentioned pvc to me. He's was complaining about rust in my steel lines as he was replacing the leaky regulator on my new VF6SS.
  • Page 1 of 4 1234 LastLast
    1. Compressed air supply required for 50A plasma..
      By hotponyshoes in forum General Waterjet
      Last Post: 04-15-2007, 09:16 AM
    2. ReOrdering lines
      By rherman in forum BobCad-Cam
      Last Post: 12-21-2006, 12:34 PM
    3. How to hide lines in MC9?
      By J-ken in forum Mastercam
      Last Post: 07-13-2006, 08:34 AM
    4. Help! Getting the oil out of my compressor lines
      By SRT Mike in forum General Metal Working Machines
      Last Post: 06-01-2006, 07:16 AM
    5. Can't see lines
      By Mr.Chips in forum TurboCAD/CAM
      Last Post: 04-03-2005, 11:29 AM
