| CNCzone Club House Discuss everything in between CNC. THIS IS NOT A TRASH BIN. |
I have to make close tolerance holes i.e. +/- 0.0002 on diameter. I could bore the holes, but it is kind of a production application with many holes and various sizes, I don't want to have to "Tweak" in every hole.. the holes are 1.5" diameter to about 3.5" diameter, otherwise I would just ream them. Does anyone have any ideas for a tool that large that would be like a reamer? Or where to buy large special size reamers? |
| Buy yourself a boring head and bar for every hole. Shars Tool Co has a small selection of boring heads for cheap. Now, these are not "tenth's set quality", so you will have to tweak and fiddle to get them cutting to size. But, it beats resetting one boring head over and over again. I am assuming that your spindle taper is in excellent condition and capable of accurate repeat positioning of the toolholder.
what is the hole depth? your going to need something quite rigid to avoid any taper , carb, bars would be best like Hu said your going to need a good clean spindle to achieve any repeatability or you'll need to tweak every hole in order to avoid picking up chips or any dirt ,i'd suggest hand bombing the boring heads in and out of the machine after the hole is done ive seen far too many times guys getting confident with the boring and they end up oversizing the dia because the tool didn t seat properly |
| tolerance | heilcnc | Benchtop Machines | 0 | 04-29-2006 08:31 AM |
| Gecko - close to computer or close to motor? | andy_ck87028 | Gecko Drives | 1 | 11-27-2005 10:39 PM |
| PVC - Solvent and oil tolerance? | Chris D | Glass, Plastic and Stone | 4 | 10-11-2005 07:39 AM |
| 'tolerance' for STOP logic | squarewave | CamSoft Products | 6 | 09-11-2005 11:34 AM |
| Geometric Tolerance | BlueChip | General CAM Discussion | 9 | 11-02-2003 03:29 PM |
