Go Back   CNCzone.com-The Largest Machinist Community on the net! > Events, Product Announcements and More > CNCzone Club House
CNCzone Club House Discuss everything in between CNC. THIS IS NOT A TRASH BIN.
Old 01-26-2007, 07:49 PM
baran3 is on a distinguished road
*** Positioning Problem ***
I am working on a Kitamura Mycenter2 circa 1983. There is a positioning problem with the Y axis when the machine is "cold". I made a test piece where i bored two holes at the end of one day. Then i bored a third hole at the beginning of the next day. The two holes i bored at then end of the one day were accuratly spaced from each other, but the one i did the following morning was .004 from its programmed location in the Y axis. (The X position was perfect). I've tried locating a surface and then running an then moving the table in a looped program for more than an hour to see if I could pick up a change, but the most i got was only .001 when i used rapid movement to warm it up. Feeding an arc produced no change in my zero. The Y axis motor on this machine is not directly connected to the ball screw, there is a shaft that connects the two. This is the only machine we have like that. Does anyone know what the problem may be? ....
when i warmed the machine up i never turned the spindle on or moved the z axis. could the positioning problem possibly be here and if so how.
*** Positioning Problem *** baran3 General Metal Working Machines 0 01-23-2007 07:25 PM
DRO positioning is Wrong.How to fix? GisMo Machines running Mach Software 5 10-15-2006 07:20 AM
Boss 5 X axis positioning kewl_cat Bridgeport and Hardinge Mills 1 01-07-2006 10:04 AM
Fanuc O-M positioning 723 General Metal Working Machines 8 07-30-2004 08:09 PM
photomicroprocessors for positioning turmite General Electronics Discussion 0 06-24-2004 11:37 AM
