Go Back   CNCzone.com-The Largest Machinist Community on the net! > Events, Product Announcements and More > CNCzone Club House
CNCzone Club House Discuss everything in between CNC. THIS IS NOT A TRASH BIN.
Old 01-14-2007, 12:52 PM
tybrenis's Avatar
tybrenis is on a distinguished road
Home made encapsulating machine?
Hey guys,
Do you think it's possible to build a soft-gel encapsulating machine? How much do you think it would cost, what would be required, etc?
Old 01-14-2007, 01:29 PM
What is a soft gel encapsulating machine?
Old 01-14-2007, 02:04 PM
tybrenis's Avatar
They use them mostly in the medical industry to make gelcap pills. Basically, they automatically inject and seal a liquid (usually medicine) into a gelatin capsule. I was hoping to build one to manufacturer paintballs.
Old 01-14-2007, 03:42 PM
avliet is on a distinguished road
Paintball machine
Hey Tybrenis, If you want a swanky machine, you're in for some work... but... here it is... Why make things more complicated than they have to be: Take a page from Cadbury - makers of the Caramilk bar... Freeze your paint into little round pellets, pop each one out of it's container, dip it in latex / whatever to give it a thin coat, and let them thaw... This should work fine as, from what I remember, the paints you'd want to use are all water based... Your challenges are more in how to shape your molds for mass production and how to dip / dry the latex on the balls before they start melting. Maybe a special type or mixture of plastics will work for the last part. Careful how thick you make the coating. Paintballs already hurt - you could do some real damage if you make the skin too thick. Off you go - Play safe now... *pat on the head* Regards, ARVliet PS - Probably cheaper to just buy the darn things.
Old 01-14-2007, 03:45 PM
tybrenis's Avatar
Thanks for the advice, I'd never thought of the approach.
Thing is, paintballs are very precisely made, and while theya re all ".68" caliber, they vary from .679 to .691. These tiny little differences can make a big difference on the paintball field.
I'm just messing about and seeing what I can come up with here, its by far not a big deal to me. I jsut thought it'd be cool, even if buying them is probably cheaper anyways... =D
Old 01-14-2007, 03:56 PM
AMCjeepCJ's Avatar
AMCjeepCJ is on a distinguished road
I just saw a program called, "How it's made" on Discovery or TLC last week on this very same topic, might be worth watching that show to see how it's done in bulk...
Gimpy aka 313 (three thirteen)
The early bird may get the worm, but the second mouse gets the cheese.
tybrenis's Avatar
That's where I got the idea for this... hehe. That's my favorite show.
Old 01-15-2007, 10:10 AM
VoxLimbo is on a distinguished road
Possible Technique
You could use a two shot molding. Inject the shell, rotate the mold for the paint shot, inject the paint, and heat seal the opening.
But, perhaps it would be better to blow mold this using the injection of the paint mixture itself to to expand the outer coating into the mold. It will depend on the working temperatures of your ingredients.
The earliest injection macines were manual, using a heater and a lever for the injection itself. You could make such a machine for your prototype work.
Be carefull you don't run afoul of the DEA. Capsule manufacture equipment, as well as tableting equipment is closely watched due to it's diversion into drug manufacture.
The other consideration is that the tollerances you are trying to meet are only partly due to the accuracy of your mold. you will get much more size variation from the molding process itself. The molded material will shrink while cooling, and expand when exposed to moisture. This will be dependent on your material selection, feedstock humidity, process humidiity, injection and tooling temperature, injection rates, injection and extraction timing.
Good luck,
Albion.
Old 01-15-2007, 10:17 AM
MnotLyon is on a distinguished road
I like your idea, but most paintballs are oil based. They make lead shot by dropping it from a tower. The drips become round as they fall, and they fall into water. Maybe something similar could be done with paintballs. Maybe somebody could formulate a paint that would create it's own shell when dried, so it could be dropped too.
To the OP:
If you're trying to find cheap paintballs, call National or PMI. You're not going to make them any cheaper.
OTOH, if you're looking to come up with a BETTER paintball, you need to get away from the encapsulating machine. Maybe an idea like avliet's is the way to go. You need to get rid of the seam, and insure a more round paintball.
If you really wanna do something different, make a more accurate paintball shape. Something more bullet shaped that could accept rifleing, or maybe arrow shaped that doesn't need rifleing. Of course, then you'll have to come up with a new gun to shoot them.
Old 01-15-2007, 01:55 PM
aball2 is on a distinguished road
No seam would be good but do I here Golf
Dimples might be a good way to go. How much money has been spent making a golf ball go that extra mile? There are already barrels that force the ball to spin if dimples are added that would have to add the the lift!
  #11   Ban this user!
Old 01-15-2007, 04:04 PM
Rather than getting rid of the seam, perhaps it would be better to create more seams in a balanced way such as a buckyball or geodesic pattern.
