| CNCzone Club House Discuss everything in between CNC. THIS IS NOT A TRASH BIN. |
I am drilling .250 X 5.25 deep in 303 s.s. im just looking to see if anyone had any good ideas on running this,any suggestions on feeds and speeds and depth of my pecks and amount of retracts i have a solid carbide oil through drill with 7. of cutting lenth |
| I ran a TiAlN coated Titex drill in 17-4 @ 2055 rpm and .0035 ipr. I started at .001 ipr until the tip was started and then went up from there. They (Titex) claimed that you didn't have to peck but I did. I drilled the 1st inch, pulled out, drilled another 1/2 inch pulled out, etc.. I basically stepped down the deeper I went. I was only going 3" deep though. 5.25" with a 1/4 inch drill....that's deep.
__________________ I don't know much about anything but I know a little about everything.... Last edited by cdlenterprises; 12-21-2006 at 01:39 PM. Reason: wrong depth |
| Yeah the first drilled i ran was a carbide tip i ran a bit slower than that i was fast pecking then retracting all the way out i did that several times i got about thirty patrs and broke it so i got this HIGH dollar drill and now i dont want to run it HA HA |
| Jackson, You're supposed to buy a tool like that about a year in advance, so you can admire it. Then, when the thrill of newness is gone, you get fed up and use it. Oh, BTW, you should order 2 if you want the first one to last forever
| jackson, You might consider thru the tool high pressure (air + coolant) blast. I asume you have an enclosure around the machine. With enough flow, you may not have to peck your way thru. I believe the drills are available down to 3/16".
__________________ DZASTR |
| I ran job on my cnc lathe last week it was a .25 hole 6 inchs deep. I tryed some parabolic drills but the holes would drift a few thou.bad surface finish lots of pecks. So i tryed a gun drill i bought it from sterling drills I called them and they said i would need a least 900 psi coolant pressure not to have to peck any less an I would have to peck I only have about 65psi on my lathe. Anyway I bought one and it worked great i had to peck but it was alot better than a twist drill the hole stayed stright and the finish was like a miror. http://www.sterlinggundrills.com/dee...undrills.shtml
__________________ Tim |
#10
| The gun drill was around $70 ,I ran it at 3500 rpm at .001 rev. The gun drill tip breaks the chips up so the coolant can flush the chips out. The slower the feed the smaller the chip. It took about 2 1/2 min.per hole. It worked much better than the Guring and Tidex parobolic drills I tried. If you use a gun drill you must use a pilot hole the same dia.to start it.
