Go Back   CNCzone.com-The Largest Machinist Community on the net! > Events, Product Announcements and More > CNCzone Club House
CNCzone Club House Discuss everything in between CNC. THIS IS NOT A TRASH BIN.
Old 10-05-2006, 05:46 PM
diarmaid's Avatar
*Registered*
diarmaid is on a distinguished road
This is SO COOL!! 'Polymorph'
Hi folks,
I found this stuff today called Polymorph. Its plastic granules that melt to a permeable state when heated above 62degC. It can be molded and formed into almost any shape when malleable, and then hardens again to a tough hard solid plastic. When hard it can be machined or cut, sanded or painted.
Below is an example of what I did with it today to test it. In the bowl you see a small bracket that was my first attempt at making something with it. I poured in just boiled water, then took out the permeable stuff and squeezed out the water. As you see I re-heated the bracket to use the plastic again. For my second attempt I formed two pivot stands for a gate I made, shaping the plastic when hot around the hinge bars as shown in the pics (No jokes please, I know what it looks like!). I squeezed flaps on the sides and two 'feet' because Im going to set the two plastic stands into concrete and then sit the hinge bars of the gate into them! Tomorrow Im going to sand the stands and cut them to even out the tops a bit, then keep the cut-offs to be re-used later, no waste!
The plastic is completely re-useable and is also bio-degradable. It doesn't say how bio-degradable, but Im banking that set in concrete it'll last a few years at least.
Think of the numerous uses!!! Ball joints, so many different types of brackets, custom handles for stuff, etc etc........
Its expensive if you want to make a large object, this little tub cost €32. But if your making hundreds of very small parts that dont use much plastic each but would cost a lot to get custom made, then it's great value.
ID:	23709   Click image for larger version
ID:	23710   Click image for larger version
ID:	23711   Click image for larger version
ID:	23713   Click image for larger version
Old 10-05-2006, 07:06 PM
Al_The_Man's Avatar
It apears to be UK based and available to Europe, I wonder if it is marketed elsewhere under a different name?
Old 10-05-2006, 09:50 PM
I found mwntion of polymorph here including US sources:
http://reprapdoc.voodoo.co.nz/bin/view/Main/Polymorph
The reprap site in itself might appeal to some people.
Old 10-06-2006, 02:51 AM
diarmaid's Avatar
*Registered*
Old 10-06-2006, 02:52 AM
diarmaid's Avatar
*Registered*
Thanks Geof, very useful link. I bought mine from Maplin in Ireland. Im not sure I like that reprap, self constructing, self replicating, evolving machine....thus begins the age of robots and the decline of man!
http://reprap.org/
Edit: Argh! Posted twice by accident, that's happening a lot lately. I blanked out the post above, it said the exact same as this one.
