Go Back   CNCzone.com-The Largest Machinist Community on the net! > Events, Product Announcements and More > CNCzone Club House
CNCzone Club House Discuss everything in between CNC. THIS IS NOT A TRASH BIN.
Old 09-04-2006, 04:37 PM
Art Ransom's Avatar
Art Ransom is on a distinguished road
Large A axis (rotation) control HELP!!
I am building a 4 axis mill with 24" A axis to make wooden columns. I want the ability to carve on the columns but that creates motion control problems. ie backlash. Best idea so far is using 24" gear on A axis and 1" gear on stepper either planatery or worm. Surely someone has a better idea.
Old 09-04-2006, 04:43 PM
Al_The_Man's Avatar
There is not a great deal of choice if you want accurate reduction, if you are looking at 24:1 Then I would source a planetary gearbox off ebay, They are compact, low backlash and high ratio's.
Bayside and Alpha are a couple of good makes.
Old 09-05-2006, 04:11 PM
ART RANSOM, How about a double reduction timing belt drive? Keep the belt tension tight, use good radial bearings. Place a bearing outboard of the driving motor to keep from overloading it's bearings radially. I've used this method on machines requiring very accurate timing/indexing.
DZASTR
