| CNCzone Club House Discuss everything in between CNC. THIS IS NOT A TRASH BIN. |
Some time ago I thought I came up with an original idea of a laser tool path displayer, only to be shown that they already exist. The advantage of such a device is that it displays the tool path the exact position that the machine will cut. This means you can safely know where to screw down your work and not cut though a screw, also you can use scrap bits of timber and know if your work will fit into it. Obviously it would need to get the information from mach in order to display the path. I was wondering a few things........ Would any one be interested in designing the laser device and posting a build guide. Could Mach be made to do this ? Do any of you see an advantage of such a device? It should be quite cheap to make using a $10 dollar laser a mirror and some soliniod device. Any thoughts? |
| ben, it would seem easier to have the device load gcode and interpret it directly? otherwise mach would need provisions to extract the vector information from the on-screen display and somehow transmit just the area of interest to the scanning head... i would imagine if someone out there has done a project to draw line-art vector images with a laser, this could be 'easily' adapted. i would think the real challenge must be having the laser. job start point, etc, line up.... |
| "It should be quite cheap to make using a $10 dollar laser a mirror and some soliniod device." I think you are being very optimistic here. It is correct that all you need in principle is a laser and a mirror controlled by two solenoids; actually they would not be simple solenoids but would have to be something similar to a speaker coil which can be precisely moved like a servo. However, there are two big challenges: The first is the angular accuracy required in the positioning of the mirror. The mirror would need to be above the work area by at least twice the maximum dimension to be scanned and the image on the work area would have to be precise to within maybe 0.010". For a 50" maximum dimension this means the mirror has to be controlled to within 1 part in 5000 which is quite precise. The second challenge is doing it fast enough; you have to write a line with the laser spot which means you have to come back to every spot on the line at least 30 times a second in order for persistence of vision to give the impression that a line exists. This combination of precision and speed will not be easy to obtain without some fairly sophisticated engineering. |
| check this out, could be a good start. http://elm-chan.org/works/vlp/report_e.html
__________________ Mhel "me and my unselfish genes" |
| Geoff, since its main use would be for roughly knowing the position the tool will travel along, I dont know if the accuracy you are talkning about would be needed. Slp_prlzys, Thats a very good link indeed. Thanks for that. Vaccy, Since I made this post, a friend mentioned the idea of using DLP technology. That got me thinking about another idea. If instead of using a laser you used an old low res video projector. You could then have your computer set up as a dual monitor set up. Make the tool path display on the second monitor. This would mean there would not need to be a math processor thing happening, and is just a projected display of the existing toolpath on the work piece. You should be able to calibrate it using the lens focas, visual settings, and by moving the video projector the right distance away. Last edited by ynneb; 05-10-2006 at 08:11 PM. |
| Yeh the more I think about it the easier it would be to use a video projector. In Mach3 it is easy to make a wide screen that spans over a dual monitor setup. If you had the toolpath display that mach already has, on the second monitor, and the second monitor was a video projector, essentially you have every thing you need. How simple, nothing special needs to be done, cheap second hand low res monitor, and a screen tweak for mach that any one can do. If anyone wants to give this a try, and doesnt know how to make a mch3 wide screen, let me know and i will do it for them. I must admit the flickering laser is cooler though. |
| You are probably right to try the projector idea but I wouldn't spend too much in case you can't tweak it as well as you would like. Another problem would seem to be that the toolpath view scales with the toolpath so perhaps it would be better to project your CAD, you could draw a box the size of your work table and always put your cad in that, then do view:zoom:window and select the box, full screen preview and you are away. Graham |
| i think you could find old, crude 'overhead projector LCD screens' on ebay.. ive got one i got for free and never used much.. http://cgi.ebay.com/INFOCUS-BOXLIGHT...QQcmdZViewItem http://cgi.ebay.com/Infocus-1600GS-5...QQcmdZViewItem http://cgi.ebay.com/nView-ViewFrame-...QQcmdZViewItem |
#10
| Just a thought....but you most likely don't want to see the entire tool path since that would take some time to display that info....maybe just the perimeter or any islands around a place where you could have a fastener.... |
