Go Back   CNCzone.com-The Largest Machinist Community on the net! > Events, Product Announcements and More > CNCzone Club House
CNCzone Club House Discuss everything in between CNC. THIS IS NOT A TRASH BIN.
Old 05-06-2006, 10:05 AM
KAG65 is on a distinguished road
What the Best 3D sketch modeling process?
Studio 3D sketch modeling is 3D brainstorming in real time. Very powerful tool for concept modeling. Real time morphing surface or point cloud works if have node to node connectivity. Together with 5 axis CNC make prototype dreams come true. The morphing video with changes took about one hour real time. Used this process it Ford PDC and milling full size mustang (s97). 3D Digital boundaries in design is knowing the process up front through the cnc machining of product. Don’t imagine the shape bend reality with style. Reverse engineering using Point cloud stl and surface data and CNC milling 5 axis requires High quality surface parameterization used to define tool path G & M code. I have milled the S97 mustang hood stl with ½ flat end mill tool running 9 mm step over. So it does work in the studio if you know the Process and have strong education and Background. Software does not make processes requirements do! So the question is. Why Not try new process?
Another Post Example Concept Car Morphing
http://www.millit5.com/Car9.html
KAG65
Chief CNC ENGINEER
http://www.millit5.com/index2.html
Old 05-08-2006, 04:39 AM
Moderator
Dan B is on a distinguished road
Is there a real question in there somewhere?
Dan
Old 05-08-2006, 07:17 AM
JavaDog's Avatar
JavaDog is on a distinguished road
Not that I can see. Interesting looking software though...
Check Out My Build-Log: http://www.cnczone.com/forums/showthread.php?t=6452
Old 05-08-2006, 07:43 AM
cbass is on a distinguished road
Dan
lol...
you guys must learn to read between the lines
Yes KAG65, I would definitely choose steel over aluminum when building a machine that big. Unless of course you don't have access to proper tools.
Carlo
