Go Back   CNCzone.com-The Largest Machinist Community on the net! > Events, Product Announcements and More > CNCzone Club House
CNCzone Club House Discuss everything in between CNC. THIS IS NOT A TRASH BIN.
Old 05-04-2006, 12:03 PM
avengine is on a distinguished road
simple circuit for step motor?
I just buy one step motor: oriental motor PK244-02BA with 6 wire DC
0.8A 7.5ohm 2 phase and a ic MC3479P stepped motor driver,
would like to know is there some simple circuit I can build and test
the step motor from the pc?
this 2 items cost me $12 but I think is the good start to learn
something new.
thanks
Old 05-04-2006, 05:50 PM
pminmo's Avatar
pminmo is on a distinguished road
There are several pages on my website you may find helpfull towards your goal. One problem you have is the MC3479P is probably a little shy on current ability for your motor.
Phil, Still too many interests, too many projects, and not enough time!!!!!!!!
Vist my websites - http://pminmo.com & http://millpcbs.com
Old 05-04-2006, 06:32 PM
is there any other suggestion on the driver? normally how much current is suitable?
my plan is to make one step at a time, if geckodrive is a good start ( what model?), then I don't mind to start with using something that is more or less plug a bigger motors and it will go better.
thanks.
Old 05-05-2006, 11:07 AM
vulcom1 is on a distinguished road
From a circuit with 3479p I have made the schematic called for 4 3055 's on the output. I am not an electronic guru but a hobbiest and it is working for me.
John
Old 05-05-2006, 11:20 AM
your circuit sound interesting to me too, can you share with me. you can email to output123@gmail.com
btw what is 3055 is that the power transistor?
Thanks.
Old 05-05-2006, 12:13 PM
The 3055 is the power transistor and I will either draw a diagram up or see if I can find the circuit.
John
Old 05-05-2006, 12:21 PM
thanks a lot, and you are in canada too, I am in Richmond Hill, ontario.
to save you time, you can just take a picture of your setup and a simple diagram of the circuit, I can figure it out on my side, where do you go to buy your stuff? I find it is not that easy find parts that is reasonable price in Canada. not that many surplus shop around.
Old 05-05-2006, 01:32 PM
In the 60's live on Poyntz ave. just south of Sheppard so know the old Richmond Hill.
I have this schematic from Sayal in Toronto off there site but not sure if they still have it on. You can have a look to see if anything is interesting for you. I use a breadboard to try everything then go from there. Mine is a 6 wire stepper. I installed led's on L1,2,3,4 with 1k resistor's to the base of the 4 2035's. Emitters go to ground and the collectors are to the coils. The 2 power wires are separate power and might need a resistor in the lines. If you do a bit of a search you can find how to hook to a pc or what ever you want to do. I used to have a lot of area's to look at but cleaned my pc up.
I built the EDM(sinker) from Stictly IC awhile ago but had to change a few things like the 5804 to the 3479. It is not computer controlled but the timing and other things are adjustable. Works for me anyways.
I started purchasing from Digikey as every time I try in Calgary they never seem to have everything. I live in Vulcan Alta. 1/2 way between Calgary and Lethbridge and it gets expensive when you travel and come up short.
Hope this is of some help.
John
