Go Back   CNCzone.com-The Largest Machinist Community on the net! > Events, Product Announcements and More > CNCzone Club House
CNCzone Club House Discuss everything in between CNC. THIS IS NOT A TRASH BIN.
Old 10-31-2003, 10:06 PM
jbbaird is on a distinguished road
Talking creative/ingenius folks here!? need help
some folks here definitely come up with some creative stuff ....
I cobbled together a 36x36 belt driven x-y table - originaly to use for a laser cutter/engraver. Table works but we found an industrial laser cutter on ebay for less than the laser and optics were going to cost. I'd now like to use the table for drilling (I'm in wordworking so my idea of precision is sloppy to some of you guys). The ganrty was never designed for much weight (was to move optics only for a stationary laser) so I can't mount a router to it. I was thinking about a pnumatic grinder to spin the drill bit ($20 at HD and designed where it would screw right into a tapped 1.125 hole). I have some Bimba Air Cylinders that could lower the spindle (retract by spring???) - going down this road, the only thing left to overcome is the high speed of the grinder (20k+ rpms). I'm only drilling 3/8 holes in 3/4 ply. I don't know squat about air tools but it should not be too tough to slow this down (with a mod, not gearing).
Any thoughts on this? anyone have any better ideas for a lightweight z axis and spindle for light drilling?
Thanks in advance,
Joe
Old 10-31-2003, 10:37 PM
Max's Avatar
Max Max is offline
Max is on a distinguished road
How about one of those flex-shaft engravers?
You could hang the engraver motor centered over the table and mount the flex head to your gantry.
It shouldn't be a problem to have variable speed.
I don't know if the chuck would be large enough to hold a 3/8 bit.
An idea though ....
To me, a pneumatic head would be noisy
Old 11-01-2003, 07:36 PM
balsaman's Avatar
balsaman is on a distinguished road
Noisy and NO torque at all, especially when slowed, which would have to be done with a flow control in the line to the grinder. Also be prepared for a 3 HP compressor for every horsepower you think you might need for drilling...not too efficient.
I would go with a Fordom tool and flex shaft, as suggested above.
Eric
I wish it wouldn't crash.
Old 11-01-2003, 09:39 PM
ARB's Avatar
ARB ARB is offline
ARB is on a distinguished road
How about mounting a basic 3/8 or 1/2" electric drill for your spindle and power source. Your basic 3/8 DeWalt electric drill does not weigh much or cost near as much as the Foredom tool. It can also handle a larger drill bit.
If you want to go hi tech look out on ebay for a Desouter drilling head. These have all the feed and return features built in. They are a fantastic unit.
ARB
ARB
"That Will Be a dollar for the work and a dollar for knowing how" FB
Old 11-01-2003, 11:46 PM
turmite is on a distinguished road
I wonder if something like this would work??
1) 10,000 RPM Miniature 36mm ULTRASPINDLE NEW Brushless Motor
Diameter = 24.6mm, Height = 36mm,
Rugged, shock resistant,
Three Phase, 0.6 ohms/phase motor. High torque from rare earth magnets,
Highest quality ball bearings, Designed for 300,000 hour MTBF.
APPLICATIONS: Diamond Turning, Optical scanners, Gyroscopes, Stabilizers $49/ea
2) 10,000 RPM Miniature 20mm ULTRASPINDLE NEW Brushless Motor
Diameter = 24.6mm, Height = 20mm,
APPLICATIONS: Diamond Turning, Optical scanners, Gyroscopes, Stabilizers $39/ea
www.lasermotion.com/servo.html
turmite
No greater love can a man have than this, that he give his life for a friend.
What are folks using for home & limit switches? rustyolddo General Electronics Discussion 21 07-18-2005 06:01 PM
sign folks and their software? Crushmonkey General CNC (Mill and Lathe) Control Software (NC) 0 05-21-2005 03:57 AM
Thanks Boss302 OneCNC 44 07-21-2004 11:51 AM
