Go Back   CNCzone.com-The Largest Machinist Community on the net! > Events, Product Announcements and More > CNCzone Club House
CNCzone Club House Discuss everything in between CNC. THIS IS NOT A TRASH BIN.
Old 04-25-2006, 07:19 AM
avengine is on a distinguished road
question about X axis has 2 motors on big router
on the big router table, usually they have 2 step motors one on left, and one on the right, I do think that they need 2 geckodrive to drive them, but I am not sure on the controller side and mach3, do they have 2 port to output in order to control this x-axis,
I am not sure if I send out a commend to move 1" on X axis to the controller card, is that go to 2 different ports on the controller, then go to 2 geckodrive, is this the way it work?
the reason I ask is a lot of controller spec said they control 3 axis, is that already mean I can control 4 motors in total base on the x-axis motors is common? or should I buy the 4 axis controller?
Old 04-25-2006, 09:28 AM
ger21's Avatar
Use two drives for the X-axis, one for each motor. In Mach3, you set one as a slave to the other. Mach3 will keep them in synch.
Old 04-25-2006, 09:29 PM
what is pro and con of Galil coding compare to G-code
thanks for the info.
Sound like mach3 is such a powerful program.
Did you heard of the company Galil, I ask them about their hardware and software, they are so expansive and they are not using G-code, what is special on their stuff?
