Go Back   CNCzone.com-The Largest Machinist Community on the net! > Events, Product Announcements and More > CNCzone Club House
CNCzone Club House Discuss everything in between CNC. THIS IS NOT A TRASH BIN.
Old 03-27-2006, 08:19 AM
watzmann is on a distinguished road
New amazing problem:)
Hi All ,
i have a machine named " Feeler FV 800 " with a control "mitsubishi cnc Meldas M3"
i need to refrance the axis of this machine i don't know how .
i mean when i turn on the machine , it can rotate or move or do anything unless first i have to go the home position of the machine , but i can do it
in case anyone have a machine like it and use it's control please help me .
Ali
Old 03-27-2006, 08:30 AM
cbass is on a distinguished road
Does the machine have a "home" button?
Old 03-27-2006, 10:03 AM
Al_The_Man's Avatar
Is this a Mill? If the original machine tool builder programmed it that the axis requires to be homed before it can be run in auto, then there should be a position on the function switch labeled accordingly, rather than letters it may be the universal symbol for homing, like a target bullseye.
Then the home position push buttons held on.
Post a shot of the operator panel if possible.
Old 03-27-2006, 11:55 AM
*Registered*
lakeside is on a distinguished road
on some machine you can go into mdi and put G01 G52 x y z 0 F1.0 but first make sure you are not on a limted switch
Old 03-29-2006, 08:41 AM
wow i solved the problem , and am writing here the solution .
the problem was an over travel in the X axis that prevents the machine from moving .
Ali
