| CNCzone Club House Discuss everything in between CNC. THIS IS NOT A TRASH BIN. |
Hi All , am having an bridgebort machine which is use a Heidenhain Control , but unforunatly i have no operator for the machine , only i have the control manual , i have some problems while using the machine. if you have any experiance with heidenhein control please tel me because i have some questions to run my machine waiting for your response , Ali |
| o.k , so my first question is : is there are any differances between the miscelanuous functions M in the differant TNC models. so i mean M4 rotate the spindle in TNC 350 what about other TNC secondly i have a machine Bredigbort i start it and then it's control then am trying to run the spindle but i can't , i don't why. i follow the steps in the control manual but spindle doesn't rotate , although the last opetaor was always do it easily , i feel i have missunderstanding with the machine . so i just can use the free wheel and move axes to specified poistions , but can't run the spindle . Air pressure is o.k , can you recommend any solutions . Ali |
| most of the m codes should be the same. M3 turns the spinde forward M4 turns the spindle reverse But you have to tell it a speed first. When you are in handwheel, press the "tool call" button. enter a speed, press enter, and hit cycle start. Then enter the M3 and press cycle start. hope that helps! chris. |
#12
Hi Ali which control of heidenhein you are having on your bridgeport. what type of problems you are having with your machine.Have you done the interfacing of your machine with the PC. regards Arshad
