Go Back   CNCzone.com-The Largest Machinist Community on the net! > Events, Product Announcements and More > CNCzone Club House
CNCzone Club House Discuss everything in between CNC. THIS IS NOT A TRASH BIN.
Old 01-29-2006, 01:34 PM
nymachinist is on a distinguished road
mach3 please help
I am trying to hook up 2 seperate boards for an x and z axis for a lathe. These boards are an interinar brand. On the input from the computer the boards have enable, step, direction, and ground. Can anyone please help me with configuring mach3. All I am getting is the motor to lock in position when e-stop is not on.
Thanks to all,
Chad
Old 01-31-2006, 07:59 AM
posix is on a distinguished road
maybe you reversed your step and direction pins? don't disconnect anything from the boards, just switch the pin assignments in mach3 ports setup dialog and try again.
hope this helps!
p.s. many "problems" with drivers and motors can be attributed to eager users wanting to see movement without first taking time to configure everything properly.
