| CNCzone Club House Discuss everything in between CNC. THIS IS NOT A TRASH BIN. |
I recently started working on a CNC machine for a computer interfacing class and I was wondering what I should expect as far as accuracy for a homebuilt project. I used smooth drawer slides that are supposedly "high precision" and I went to the local steel mill and got some aluminum for the frame. I'm using a print mech and rails from an old printer. I kept everything as perfectly perpendicular and parallel as I could. I beleive im within 1/32th of an inch accuracy. When im finished is there a program or some type of way to determine how accurate it is and how I can improve it?? If anybody has any help or would like to share their homebuilt's accuracy and how they measured please post. I will post some early pics later. |
| What do you mean by accurate??? What are you looking for??? In our shop, we have to work to tolerances of 0.0001" or better. Thus 1/32" is over 300 times too much tolerance. If you're doing wood working for framing construction, this is plenty close enough. You can probably figure within 1/32" as mentioned in your post PLUS whatever other errors creep up in your tolerance stacks ( IE: slop due to clearance, backlash and/or any lead error in your drive system(s) etc). Basically, it all adds up.... Until, or unless you machine and or tram everything into place and use precise ball screw drives, you probably can't expect much better. |
Sorry, but you'd be fortunate to keep your tooling to a 3 micron tolerance (assuming you're checking it optically), much less machining. |
| We're not checking it optically. We measure to 0.000001" with electronic encoders/counters and grind to 0.0001 tolerances on cam profiles regularly and this is done via Heidenhein encoders. Granted, we may be +/- 0.001" in absolute size but we got to extremes to control the 2nd derivative of motion curve. To do this, you MUST control the rate of change of acceleration to 0.0001"s. Takes well maintainted grinder and strict grinding procedures to do this. Our cams have won NASCAR 'Cup races many times over the past 5 years - we like to think that we know what we are doing. We also grind cams for a number of automotive OEM's (prototypes) as well as a world reknown automotive engineering firm in Detroit as well as OEM suppliers. No customers have espresse dissatisfaction with our work or have challenged our accuracy. The 0.0001' flats mentioned previously were measured on our cam measuring machine (it measures to 0.000001" electronically, feel it is demonstrably accurate to 0.0001) |
| Mkaake - For those accustomed to precision machining, .001" is a mile. It is quite easy to machine within .0004". In terms of precision grinding, this is a mile. Atomgonuclear - As far as home built precision - there is no reason that you can not attain pretty good precision with a home-built machine but it is not likely, not common and it is a lot more expensive than you would likely believe. Even achieving .003" accuracy, which would be considered pretty good for a home built machine in my opinion, requires a solid structure, fine machining and near perfect alignment of precision motion elements. Drawer slides are not precision elements in terms of machine tools but sure do beat the heck out of doing things by hand or with no machine at all. Keep us up to date. Scott
__________________ Consistency is a good thing....unless you're consistently an idiot. |
When you say within .0004" do you mean: SIZE +/-0.0004" or SIZE +/-0.0002"? Which is the commonly accepted meaning among the cognoscenti? |
| When a machinist says "a tenth", he means .0001, when a carpenter says "a tenth" he means .1. We hold +/-.0001 on our Citizen L20 swiss all day long in 303, 440, 316, etc. some jobs we have +.0000-.0001. On one assembly we did for Raytheon we had a shaft/bearing/housing assembly with 60 millionths total runout. Every one of ours bearings made in the last 18 years has not varied more than .0001 total in ID or OD. we currently have over 600,000 in stock. Yes, it is possible to hold these kind of tolerances with the right machines and the right process.
__________________ Tinmuk ********************* Any problem can be solved by the proper application of heat! |
Scott
#10
just being a smartass, anyone who works to millionths has my respect |
#11
#12
| In our case, we do onesy and twosy pieces - thus, we must have 100% of our parts made right. Thus, this issue of accuracy of parts per million is a sheer falacy to/for us. We inspect 100% before we ship and RARELY scrap out a part - a worker who does is made to realize that his screw up IS/WAS costly. Result:they take pride in NOT screwing up. We've had the QS9000 and the other questions re: std deviation, this coefficient or that posed to us. When we explain that our procedures don't fit the ppm scenario, and inspect 100% to verify quality, we've never had an issue with the Q/C depts. Besides, their argument falls appart when you hit them with the "how do you do a size distribution study when you are working with a statistical sample of one???" inquiry. We don't do aerospace work but NASCAR Nextel stuff is close - failures are QUITE visible and not tolerated. If you are shooting for a +/-0.0001" total tolerance spread, you creep up on the size. Simple thermal expansion can make the difference in a part being in or out of spec. Thus, if you "hit' size at +0.000060" (6o millionths) of nominal, you stop grinding, read size, lett cool/thermally stabilize and read again, redo/regrind if required. You also have to condider what your part is being used with. Thus, if you are making an aluminum widget that fits into a steel whatsits, the RELATIVE size at operating temp is more critical than ABSOLUTE size. YOu also have to know if the part is going to be thrown together or custom fit by the installer. All the stuff we do is custom fit by user. We still shoot for/hit the nominal size when we grind. When Mr. Honda was supposedly told by a Q/C guy that he was wasting money trying to hold better quality than 2-3ppm, his reply was, "Yes, that is true but the 2 or 3 customers got the bad parts out of the million who bought my product had a 100% defect rated which is unacceptable in any Q/C program...." I'm sure the discussion will rage on. BTW, ball bearings are made in the millions and they control internal bearing clearances within a few microns day in and day out. It is amazing but if you have to hold a particular tolerance and the customer or market demands will pay you to do it, you find a way - or else go out of business because if you don't, someone else will. |
