Go Back   CNCzone.com-The Largest Machinist Community on the net! > Events, Product Announcements and More > CNCzone Club House
CNCzone Club House Discuss everything in between CNC. THIS IS NOT A TRASH BIN.
Old 01-15-2006, 02:40 AM
watzmann is on a distinguished road
Dome!
Hi All ,
i'd like to make a dome on a cnc milling machine , am agood programmer with G-Code , could anyone tell me plz how to do that with 3 Axis only ?
Old 01-15-2006, 05:03 PM
turmite is on a distinguished road
I can think of two ways to do it. One is to cut around the dome in decending z by whatever step you needed and the other would be to cut in 3 axis either across the dome or from the center to one side working your way around.
Mike
No greater love can a man have than this, that he give his life for a friend.
Old 01-15-2006, 06:29 PM
motomitch1 is on a distinguished road
Heres some g codes that will make a dome using a 1/2" ball end mill.
I used a CAD/CAM Program
Name:	p dome.jpg‎
ID:	13844   Click image for larger version
Name:	R DOME.jpg‎
Old 01-15-2006, 06:34 PM
Sanghera is on a distinguished road
How clean of a dome with this g-code make? I mean will there be lots of ridges?
Thanks.
Old 01-15-2006, 07:19 PM
JavaDog's Avatar
JavaDog is on a distinguished road
Thanks.
A finishing pass would take car of a lot of it. Acrylic or Glass? If either, you are going to need to sand and buff/polish to get it crystal clear - but shouldn't be too bad.
Whatcha makin'?
Check Out My Build-Log: http://www.cnczone.com/forums/showthread.php?t=6452
Old 01-16-2006, 02:44 PM
actually i like this nice work , but unforunatly i don't have such a CAM software so am going to process it with my mind to write the necessery G - Code , .
am Using BObcad software but i don't have it's tutorial to generate such complicated shapes
Old 01-16-2006, 09:20 PM
watzmann if you have bobcad you have cam. What are the dimensions of the dome? Radius and height whould suffice. Give it in inches and I'll see if I can help you.
Mike
ps I wish I had the ability to do it with my mind!
Old 01-18-2006, 07:09 AM
Hiii turmitte ,
nice words from you , thanks .
the reaquired dome is 120mm diameter and height is 80mm, when you send me the G-Code ....i'll write it on Bobcam and send it to my machine.
hope to get it soon ,
Old 01-18-2006, 03:00 PM
am using ball end mill 20mm Dia
Old 01-18-2006, 09:12 PM
How do you want the gcode? G90 or G91? Where do you want the start point of the program?
Mike
  #11   Ban this user!
Old 01-21-2006, 12:54 AM
i want it an Absoulte measuring G91
Old 01-21-2006, 05:53 AM
Switcher's Avatar
Moderator
Switcher is on a distinguished road
Absolute = G90
Incremental = G91
