Results 1 to 7 of 7
Thread: How Long Should This Take To Make?
    Dec 2011
    Hello All - This is my first post and by way of introduction I have never worked with CNC machinery but I'm planning to build a CNC router for woodworking sometime down the road. At any rate I have a general question that I thought perhaps I could get some insight/answers to in this forum.
    I've attached a quick and dirty drawing I did in Sketchup (first time using it by the way) of a shape I need to have machined. It's to be made from peek plastic with an overall thickness of 6mm, outside dimensions of 51mm sq, inside dimensions of 20mm sq, recess around the 4 "legs" of 1mm, an 4 3mm holes as shown.
    So given a drawing like this with proper dimensions added to the drawing, about how long should it take for someone who's experienced with CAD/CAM software and their CNC mill to turn out something like this?
    Thanks!
    Attached Thumbnails Attached Thumbnails How Long Should This Take To Make?-socket_iso.jpg
    Registered holbieone's Avatar
    Feb 2007
    Does you pocket need no corner radius or can there be a radius , you can not mill zero radius corners
    Dec 2011
    Quote Originally Posted by holbieone View Post
    Sorry about that - forgot to attempt to draw that in Sketchup. The pocket will be used to align a square device so the inside corners of the pocket need to be drilled out to allow a square corner. So something like the attached image.
    Attached Thumbnails Attached Thumbnails How Long Should This Take To Make?-pocket.jpg
    Dec 2011
    Here's a revised shot showing the inside corner relief.
    May 2004
    The part represented, if only a quantity of 1, would never touch the CNC or the CAD/CAM. It would go straight to the manual mill and be completed in about an hour. If I took the time to program and set up something so simple for the CNC it would probably take 2-3 hours.
    http://www.kirkcon.com/
    Dec 2011
    Quote Originally Posted by txcncman View Post
    Thanks txcncman. I failed to mention tolerances which are fairly tight I believe, but good to know a CNC setup is 2-3 hours.
    May 2004
    Ok. Give me an hour and a half then for taking an extra pass on each surface to hold +/-0.001.
    1. Need Help!- Stacking Router Collet Extensions To Make a Long Bit - Good Idea?
      By NIC 77 in forum General Material Machining Solutions
      Last Post: 07-25-2011, 10:26 AM
    2. What do you make or plan to make with your cnc router?
      By piratecnc in forum DIY CNC Router Table Machines
      Last Post: 11-14-2010, 02:46 AM
    3. How long does it take to make a gear box?
      By Kain in forum Mechanical Calculations/Engineering Design
      Last Post: 03-17-2009, 12:21 AM
    4. How much is too long?
      By monte55 in forum Xylotex
      Last Post: 11-30-2006, 09:48 AM
    5. How long does it take
      By CNCadmin in forum Steam Engines
      Last Post: 11-08-2006, 10:45 PM
