Hi
I have purchased a Fecken Kerfel foam contour profile machine type c50
the problem I have is I need the software to open .sld files to run this unit,
you can not just put a nc or dxf file into this baby it does need to converted
to an .sld format not the same SLD that autocad use.
There must be somebody out there that knows about this process, I have spoken to the manufacture and they only want to covert the machine to run
on g codes on windows system at a very silly price.Please help in any way you can
if at all possible thank you.
best regards
Frank
