Results 1 to 6 of 6
Thread: Help with stepper motor!
    Nov 2011
    Norway
    Hi! I am building my own cnc miling machine, and I am using this driver circuit for my stepper motors. My question is: what motor should I use, and Where should I buy it? Regards, David
    Registered doorknob's Avatar
    Jan 2010
    That circuit is a very simple stepper motor driver that may be adequate for a small machine, but may not be suitable for a larger machine.
    Can you provide more information about the milling machine that you intend to use?
    The circuit requires a 6-wire stepper motor (or an 8-wire motor wired up for unipolar operation).
    I know of many places from where you can get such motors, however they are all located in the United States. Perhaps someone else can suggest a local source for you.
    Nov 2011
    Norway
    My milling machine is about 60X50 cm, and I was thinking of using some nema 23 motors with 270oz/in. Do you think this is a good choice? , and if so; where can I get some "cheap"? If I buy these motors in Norway, they'll cost about 250 USD a piece...
    Jan 2010
    This motor has 6 leads and is rated at 21 kg-cm holding torque (which, if I have done the conversion correctly, is about 290 oz.-in.):
    3.6V/3A/1.8 Deg. NEMA 23 STEPMOTOR-MPJA, Inc.
    This looks like the same motor, but with a lower price:
    21.0 kg-cm 6 Wire NEMA 23 Stepping Motor
    Nov 2011
    Norway
    I looked at the one you posted, but they don't ship to Norway.. any other sites? Thank you for helping me out with this
    Jan 2010
    Did you try both vendors?
    Here is a 280 oz-in motor with 8 wires (which can be connected as a 6-wire motor), but it's a bit more expensive:
    280 OzIn 8-Wire Stepper Motor -
    1. Need Help!- Power Supply for 4 Stepper Driver 32-65VDC and 4 Stepper Motor 65V 2.3A
      By guy2b1 in forum DIY CNC Router Table Machines
      Last Post: 03-08-2011, 06:50 AM
    2. Need Help!- 6 leads stepper motor connect to TB6560AHQ stepper driver board
      By wf1318 in forum Stepper Motors and Drives
      Last Post: 07-25-2010, 03:19 AM
    3. use satellite dish actuator motor as a stepper motor
      By ozni in forum Stepper Motors and Drives
      Last Post: 06-18-2010, 08:55 PM
    4. Integrated stepper motor? with built-in stepper motor driver
      By uirobot in forum Product and Manufacturer Announcements
      Last Post: 06-07-2010, 04:59 AM
    5. Beltdrive-stepper motor-stepper motor driver
      By Georg in forum Stepper Motors and Drives
      Last Post: 10-16-2007, 05:56 PM
