| CNCzone Club House Discuss everything in between CNC. THIS IS NOT A TRASH BIN. |
Right now my cnc machine is in a small utility building on my parents property which isn't very far from my house. I am wanting to get a small workshop built on my own property before too long. This got me to thinking who has small workshops on here. I've seen some pretty nice small workshops on here before, some even in apartments and on balcony's. If you have a small workshop feel free to tell about it and if you like, post some photos. I would love to see how you guys are making use of the small spaces. |
| Well I was granted a small dead end of my basement. thats about 9 x 6. With a mill in there, a lathe, bunch of electronic boxes to house stepper drivers, 2 benches for tooling, and a computer...its a tight fit. Even though they are small Sieg machines, at least I dont have to move a hell of alot when switching between lathe and mill |
| I was gonna say my 19 x 25 was too small too. When you're table saw takes up 8ft x 8ft of floor space, it starts getting small fast. Add a workbench, a 40" x 60" router, band saw, drill press, lathe, compressor..... and there's no room to work
| 12x14. Table saw, chop saw, band saw, CNC, router table, lathe, drill press, belt/disk sander, jointer, planer, bench, compressor, vacuum, tool chest, hand tools, clamps, wood. One man shop. No girls allowed. |
| My shop is a single mini lathe (CNC's) on a small bench on my balcony. You could say the shop is infinitely large cause it is outside ![]() http://www.wrathall.com/Interests/machining/My_shed.htm
__________________ Regards, Mark www.wrathall.com Last edited by RotarySMP; 10-08-2005 at 03:35 AM. |
| When broke and just out of school my shop was the "extra" bedroom ( a bump in a hallway) in a 10 x 40 mobile home that I lived in. Most everything was done in the yard through the door. Ahh, good riddance to the bad old days. Things I've found useful: Make a work bench that is tied to the wall(s) but open underneath for flexible storage. Choose a counter-top height that fits your body and make every surface this height; that way long materials can be placed anywhere spanning any distance and they will still lay flat and level. Put all tools and cabinetry on (locking) wheels. A well placed extra door or window can be opened to allow longer lumber or metal through the wall for cutting/machining. Headroom! A gambrel roof is a cheap way to gain enough room to flip a stick/ joint/ board from end to end. How small is small? It may be worth checking out the prefabbed sheds at Lowes and Home Depot. They are getting quite good at designing these things to use every bit of material efficiently. I am expanding once again and will build my own extra space with better materials, but the dimensions and framing methods of these prefabs are worth considering if cost is an issue, and it always is. Good luck!
__________________ David www.solsylva.com |
| Trapped like a shop rat, I am forced into this dark corner of the basement. The wifey will not let me expand beyond these four walls, so I have to make do with what there is. FYI: It is MUCH cleaner than this old photo. |
#10
| I guess mine is large in comparision, but the amount of stuff I have in there takes up the room. 2 car garage. 1 car on a frame 1 extra car frame with spare block, tranny, transfer case (AWD) fridge oven bridgeport clone 12"x36" lathe 250dx tig welder 175 mig welder Hypertherm plasma cutter and a 4x5' table Welding table area with vise, Drill press 55 gallon air compressor horizontal band saw 11'6" blade 3 phase convertor 1 spare buick engine And on friday, sat and sunday there are 2 of us in there working I would expand things but I plan to be moving in about 8 months. |
