Results 1 to 6 of 6
Thread: MACH3 + GREX G100 - Is there anything better and newer?
    Jan 2007
    I have a 3-axis CNC machine that uses Mach 3 and Geckodrive GREX G100 motion controller. I haven't really followed the cnc world for last year and half due to numerous projects but i want to get back to cnc.
    Is there anything new that came out in terms of software and controllers? Is Mach3 pretty much what you folks still use? I'd like to move away from it for stability reasons. How about controllers, is there anything new on the market that is usb or ethernet based that has pretty fast pulse rate?
    Please let me know.. all your replies would be greatly appreciated.
    Mar 2003
    Shelby Twp, MI....USA
    There are several devices that work with mach3 and USB.
    Check out the SmoothStepper and KFLOP.
    There's also the Centipede, which is a PCI card for Mach3.
    Jan 2007
    Thank you gerry for some recommendations.... I'd like to move away from Mach3 because i need more stability.
    Dec 2003
    Quote Originally Posted by Menatep View Post
    As Gerry mentioned, there is Dynomotion (Kflop) USB and has its own MMI if you don't want to use the Mach plug in.
    Kanalog add-on for analogue drives.
    Mar 2003
    You could try Flashcut, or WinCNC.
    Or this one.
    Eding CNC - PC based CNC control
    Jul 2003
    Holmen, WI
    Try emc2.
    LinuxCNC.org - Home
    Look at mesa hardware or pico systems.
    EMC Documentation Wiki: EMC2 Supported Hardware
    It runs on linux and is very stable. I have a few machines running it - one router style using the printer port for step/dir and a full hmc with pallets, tool changer, closed loop servos and all the bells and whistles. (using mesa interface hardware)
    [nomedia="http://www.youtube.com/watch?v=39q6kvrSBSk"]‪Kearney and Trecker CNC running simple program. (tool changing and everything)‬‏ - YouTube[/nomedia]
    Love it. very scaleable.
    sam
    Edit - it is also free and opensource.
    1. Grex G100 + Linear Encoders?
      By rpseguin in forum G-REX
      Last Post: 03-18-2008, 04:12 PM
    2. Replies: 3
      Last Post: 12-04-2007, 12:29 PM
    3. Power Supply to Grex G100?
      By tulsah in forum G-REX
      Last Post: 06-11-2007, 02:56 PM
    4. Grex-G100
      By in2steam in forum G-REX
      Last Post: 03-29-2007, 01:18 AM
    5. Grex G100 Questions?
      By luis_gts in forum Mach Software (ArtSoft software)
      Last Post: 12-17-2006, 11:14 PM
