Results 1 to 4 of 4
Thread: need help
    Sep 2008
    need help
    I have a Kerry Model A.G. Mk. 3 lathe and the belt is pretty chewed up. It has 10 V grooves across( small ones ).It is appx 35 in long and I'm not sure of the width,I think it should be around an inch.There are no markings on the belt.Any ideas where I can get one from will be greatly appriciated. Also do you think a flat belt may work??Thanks
    Mar 2006
    Check with Gates, it might be a Micro-V belt.
    Dick Z
    DZASTR
    Registered DouglasR's Avatar
    Jul 2005
    I would go to a power transmission or industrial supply house and bring the belt.
    Sep 2008
    Gates was able to help me out.Thanks for the info
