I have an anilam control 3300mk (I think ).I turned on machine, reset servos,and homed machine fine. Then I moved the machine around in rapid then I flipped the switch in the back to manual. After that I reset servos and TRIED to rehome, I got a Z LAG OVER MAX error...I tried shutting down and restarting and I also tried the motion test, the servos rest fine but when I tried to move in X or Y I got a LAG OVER MAX in those axis too.Any help will be greatly appriciated. THANKS
