Go Back   CNCzone.com-The Largest Machinist Community on the net! > Events, Product Announcements and More > CNCzone Club House
CNCzone Club House Discuss everything in between CNC. THIS IS NOT A TRASH BIN.
Old 07-18-2005, 08:38 AM
ToyMaker's Avatar
ToyMaker is on a distinguished road
Sharpening Hair Clippers
My wife has been cutting my hair for years and the clippers are beginning to pull just a wee bit. I can (and do) keep keen edges on my knives, scissors, and wood-working chisels. But sharpening the clippers escapes me.
So, can anyone either explain how to sharpen these things or point me at a procedure? I googled the net and got 1.7 million ads for dog grooming tools.
tia
robotic regards,
Tom
If you say no to a good proposal, you will live to regret it. If you say yes to a bad proposal, you will regret to be living with it.
- - Dennis R. Ridley
Old 07-18-2005, 09:52 AM
Mr.Chips's Avatar
Gold Member
Mr.Chips is on a distinguished road
Clippers can be sharpened by taking the blade off and spray gluing some very fine wet or dry sand paper to a piece of glass. Try different grades depending on how much material you need to remove.
The blade is sharpened by removing metal from the entire surface. Place flat side down on the sand paper and use a little water or oil as a lubricant use circular motions and rotate the piece in your hand so the pressure is changed to keep it flat.
This grinds the material thinner and makes the edge between the "V"s and the flat part sharp again.
The indifidual "V"s are not filed like you would do a knife.
Clean the blade well before placing it back in the clippers to remove all grit.
Old 07-18-2005, 11:34 PM
ToyMaker's Avatar
Thanks Mr.Chips
I'll give it a go. Worst case - I'll wind up with a new clipper.
robotic regards,
Tom
Win friends, by all means; but also take care to befriend winners."
Old 05-05-2009, 02:34 AM
becomerLx is on a distinguished road
I think that you can see the wedding hair accessories . hoped that help you
one night
