Results 1 to 2 of 2
Thread: Tool Room Layout
    Jun 2007
    Tool Room Layout
    For those of you who work in professional shops, a few questions:
    1. How many / what kind of machines do you have?
    2. How is the layout. Are similar machines grouped together, or does each person have his own work area?
    3. Is the majority of tooling shared between machines or does each machine have their own.
    I ask because i dont think the tool room i work in is laid out very well. It is inconvenient to walk around the machines back to the benches. There is some, but not enough, storage space next to the machines for tools. And the shared tools are not centrally located.
    The shop im in has 5 bridgeports, one tm-1 CNC, 6 lathes and 3 grinders. I understand segregating the grinders (dust & such). 3 of the mills are lined up, next to each other, two are on the other side of the room. As for the lathes, they are in 2 rows of 3, head to tail, and front to front, with an isle between them. Maybe ill post some pics later if i have a chance, it would be much easier to explain.
    But i digress, what have you guys found to be a successful layout?
    MBG
    MBG is offline
    Feb 2005
    uSA
    tool room in my shop is granite table in the middle and two bridgeports on the north side and a tool room lathe on the other end, then two surface grinders on the right side.
  1. Grease for Tool Room Machines
    By AMCTony in forum Haas Mills
    Last Post: 04-03-2009, 10:36 AM
  2. Newbie- Tool Room Mill Suggestions Please
    By usmc2033 in forum Haas Mills
    Last Post: 04-23-2008, 11:48 PM
  3. Ajax Tool Room Mill
    By LUCKY13 in forum AjaxCNC Control Products
    Last Post: 03-14-2008, 12:03 AM
  4. Very slow tool change on Tool Room Mill
    By Capt Crunch in forum Haas Mills
    Last Post: 12-21-2007, 01:20 PM
