Go Back   CNCzone.com-The Largest Machinist Community on the net! > Events, Product Announcements and More > CNCzone Club House
CNCzone Club House Discuss everything in between CNC. THIS IS NOT A TRASH BIN.
Old 07-01-2005, 12:14 AM
DAB_Design is on a distinguished road
Changing Jobs
I had an interview Wed. with a somewhat local company (about 40 min. drive). Their main area is "fire-retardant structures and resin-transfer molding, especially in the use of a proprietary lost-core methodology for the fabrication of hollow structures with internal stiffeners". They just broke ground on a new 3.8million facility. And plan to almost triple employment in the next year.
I've decided to take the position. They have a newer Haas. I didn't catch the model, or the model of the controller. But I'd say it has a travel of 60 x 30 maybe. It's somewhat smaller than what I'm used to running. They also have an older 5 axis (B & C) cnc router. I can't remember the brand, but the controller seems to be somewhat 'conversational'. While being shown around by one of the engineers, he hit the cycle start on this machine. Up popped 5 options, drill, trim, can't, remember, rest .
Carbon fiber seems to be their main interest. But I also saw some other materials laying around. In their main office, they had a bicycle wheel hanging on the wall. I picked it up and was amazed at how light it was. It only had 4 'spokes', and a hole for the valve stem (I'm guessing). It was hallow, with no seams which I thought was a bit unusual. They said during the interview, that this was one of their specialties - hallow components with no seams.
Anyway, I would be doing alot of the machining, and programming. Their current plans are to eventually retire the older 5 axis machine, and purchase some newer ones. So I'm looking for a bit of information on Haas specific websites where I may be able to get some info on programming/running of the machines. The only controls I have experience with are Cincinnati Milacron.
Also, they currently use Esprit(sp?) for programming. As I have no experience in this, I'm also looking for information. The owner said he thought they were a bit hindered by the choice of using Esprit and would probably look into something else. He mentioned Catia. Hopefully I can show him a few other products and change his mind.
Most of the machining would be a small amount of aluminum for tooling, trimming finished products, and machining the foam cores for the molds. I was a bit amused by how one of the engineers 'tested' me. He said "on that piece of foam loaded in the haas, if I wanted a bunch of holes in it, and then flipped over and machinied flat, could you do that by hand at the machine?" I just about laughed. Isn't that kind of stuff really elementary anywhere you go? I would think anyone with at least 1 year of machining experience would be able to do this.
Anywhat, here is a link to an article I found about them. And here is their website.
Any information about Haas, Esprit, and composites would be appreciated.
Dustin B.
I hear and I forget.
I see and I remember.
I do and I understand.
Old 07-01-2005, 01:22 AM
Moderator
Halfnutz is on a distinguished road
Congratulations, Dustin. Sounds exciting, especially the carbon fibre and aerospace stuff. Way to go!
Halfnutz
Old 07-01-2005, 07:04 AM
Thanks Halfnutz.
I found info on the other machine. It is a Thermwood Model 70.
I have to admit, after almost 10 years at the same company, I'm a bit scared to change. But I think it would be for the best.
Dustin B.
Old 07-01-2005, 09:02 AM
turmite is on a distinguished road
Hey Dustin,
You're not going to believe this but I have had this company booked marked for a long time to talk to about one of my gunstocks projects. I can hardly wait till you get there ...
Mike
No greater love can a man have than this, that he give his life for a friend.
Old 07-01-2005, 10:31 AM
miljnor's Avatar
S.N.A.F.U.
miljnor is on a distinguished road
Haas has about 85% of the market so finding info on them should be easy... I own serveral what exactly did you want to know? I don't know the milacron control but a CNC is a CNC i learned On a funuc controler and comparatively the HAAS is much easier to use. and is An intuitive control (no guessing what switch does what). The G code language is similar, the only major changes usually happen on the Canned, and threading cycles.
thanks
Michael T.
"If you don't stand for something, chances are, you'll fall for anything!"
changing color fastolds GibbsCAM 9 01-27-2006 01:17 PM
Wanted Lathe Jobs MBG Employment Opportunity 1 05-25-2005 08:33 PM
Changing CS fastolds GibbsCAM 2 02-02-2005 12:31 AM
Changing the speed of DC motors creative_mind CNCzone Club House 3 12-02-2003 07:27 AM
Changing steps jimglass Gecko Drives 2 07-02-2003 07:20 PM
