Results 1 to 7 of 7
Thread: Change for change sake, can SUCK.
    Oct 2005
    Thumbs down Change for change sake, can SUCK.
    It might have seemed like good idea to change the way threads are presented, but what has happened is a cluster fornication. I see a new post has been made to one of the threads I've followed, I click "Last page" go to the bottom pf the page and it ends with an old and dated post. I then look at the "Post Tree" at the top, look through all the branches, waste time hunting, then give up on the Post Tree, and look up the all posts made by the poster, and in that way I find the most current post. (maybe the most current, I'll not know because of the stupid convoluted cluster piddle way threads go now)
    Please go back to the old way. This new thing might be new, but it truly sucks.
    Jun 2007
    canada
    i didnt notice any change....
    Dec 2003
    Quote Originally Posted by ihavenofish View Post
    Me neither?
    Registered port_huon's Avatar
    Dec 2007
    I think MrWild is referring to seeing a screen showing the latest post only with previous posts showing in a scroll down window at the top?
    If so, go to User CP and select Options. Under there, look for Number of Posts to Show Per Page. Set this to something other than Forum Default and the problem is fixed.
    Regards
    Geoff
    Mar 2003
    Shelby Twp, MI....USA
    You're describing what I think is called Hybrid view. Right above number of posts per page. Change to Linear-Oldest First.
    Dec 2007
    I had the same display and only changed the Number of Posts option.
    I already had Oldest Posts first selected.
    EDIT: You're right Gerry. It's hybrid mode not Number of Posts. I'm pretty sure I didn't have Hybrid selected at any stage
    but I had been logged out for a while which normally doesn't happen so changes could have been made during that time.
    Regards
    Geoff
    Oct 2005
    My options are for lineer mode, but i keep getting threaded mode. I have newest first with no cut off, and sometimes the new posts are not displayed. This started on Thursday night after several error screens saying there was a memory overload by your server. I'll try signng out and logging back in and see if that changes things. Might try a cold boot too...
    1. do you want to change your CNC for a new one
      By Nemo1985 in forum CNCzone Club House
      Last Post: 12-28-2009, 04:21 AM
    2. do you want to change your CNC for a new one
      By Nemo1985 in forum CNCzone Site News and Contests
      Last Post: 12-16-2009, 10:47 PM
    3. Newbie- bit change
      By ksl in forum CNC Tooling
      Last Post: 04-09-2009, 08:19 AM
    4. How to change Tool change position(About MAZATROL T1 control)
      By liushuixingyun in forum Mazak, Mitsubishi, Mazatrol
      Last Post: 07-07-2007, 03:58 PM
    5. change 2d to 3d
      By freezer in forum TurboCAD/CAM
      Last Post: 02-17-2004, 03:57 PM
