Results 1 to 4 of 4
Thread: Milling Slot in Aluminum
    Feb 2010
    Highlands Ranch, CO
    I'm looking to mill a 1" x 1/4" slot through the middle of some 80/20 1010 extrusion so I can run some wires from the front T-slot to the back one. Would it be best to drill a 1/4" hole on one or both of the ends of the slot and then mill out the middle or just mill it all out? I was thinking that drilling first would help with chip evacuation.
    Jul 2004
    I don't think chip evacuation will be too much of an issue- you can always hit it with a vacuum if it looks like it will be a problem. I'd be a bit more concerned about the sharp aluminum edge cutting the wires. I would definitely be fairly generous with the post filing to make sure there are no really sharp edges.
    -Matt
    Jan 2009
    Grommet For Opening
    I also think the sharp edges should be avoided for wire passage.
    There is a lot of "Build A Grommet" nylon strip out there that I would recommend for a protection/finish look.
    George
    Feb 2010
    Highlands Ranch, CO
    I'll make sure to watch out for sharp edges. Once the wires are run, both sides will have T-slot covers put over them. The wires will not move around in any way.
  1. Aluminum 'T-Slot' tables
    By ninewgt in forum DIY CNC Router Table Machines
    Last Post: 02-06-2012, 09:00 PM
  2. Aluminum T-slot workspace
    By MechanoMan in forum DIY CNC Router Table Machines
    Last Post: 05-22-2010, 10:37 AM
  3. New Machine Build- 2nd cnc - t-slot - aluminum - mdf
    By CPH-J in forum CNC Wood Router Project Log
    Last Post: 09-07-2009, 06:39 PM
  4. T-Slot Aluminum Drops
    By 80/20surplus in forum Product and Manufacturer Announcements
    Last Post: 08-10-2005, 05:28 PM
