| CNCzone Club House Discuss everything in between CNC. THIS IS NOT A TRASH BIN. |
I'm looking for a combined unit for a step timing pulley. I have thought of a ton of different ideas and need your input. Here is a picture of something i'm looking for. Basically have the Larger Pulley mated to the smaller drive pulley in any fashion (doesn't have to be machined out of a single piece of metal) |
| If you have 2 pulleys with the same shaft diameters in the center it would be easy to drill 2 holes for dowel pins and then 2 more hole at 90º to the dowel holes to be drilled and tapped for a small screw(10-32UNF etc.) to bolt the pulleys together.
__________________ Regards, Wes |
| Is there any real need to mate them together? Especially if the shaft is keyed, I usually use a set screw through to the key. Al.
I want to mate them together for simplicity sakes for my rack and pinion. i want a nice clean setup and think that would be the best bet. |
| What is a timing belt and pulley ? | ynneb | FAQ of CNC Machine building | 3 | 02-17-2012 07:35 AM |
| L Timing pulley hob? | DennisCNC | General Metalwork Discussion | 2 | 08-30-2009 03:45 PM |
| Can't find a timing pulley | chevdrgtrk | General Metal Working Machines | 4 | 07-31-2007 12:15 PM |
| can I get a 13 tooth timing pulley | unterhaus | Bridgeport and Hardinge Mills | 9 | 01-11-2006 10:11 AM |
| Calculating the right timing pulley | cnc2k | General Metalwork Discussion | 1 | 09-01-2005 07:18 AM |
