| CNCzone Club House Discuss everything in between CNC. THIS IS NOT A TRASH BIN. |
Hi I originally posted this question on another site that should remain nameless and had no response.Maybe I should have just come here first?. I have two jobs to do; 1: A1011 steel 4 x 2 x ¾ machined all over one face removing about .35 in places. 2: 44W plate steel 3 x 1.5 x .100 machined all over one face and in places only leaving .01 thickness. I would normally do this type of thing on the vacuum plate but there are thousands of them and I was thinking a magnetic plate would do the job, having looked on the net there are permanent styles which seem to be for grinding. Electromagnets I am not sure of in a VMC, and then the Electro-Permanent which seem ideal apart from plugging and unplugging to change parts. Has anyone used any of these in production runs? Would a strong fine permanent do the trick? Thanks Forrey. |
| I've been machining for about 40 years and I have never heard of using a Magnet to hold onto a part being machined. I can think of all kinds of reasons NOT TO DO IT. And can't think of any reasons to do it. I've only used Magnets to hold parts in a surface Grinder and sometimes use a mag base to take out the harmonics when turning on a manual lathe. But in a milling machine you are asking for trouble. Worst thing I can think of is the part moving. It would have to be such a strong magnet that you couldn't move the part with a sledge hammer. Make sure there is a strong barrier (like bullet proof) between you and the part if you are going to try it.
__________________ We all live in Tents! Some live in content others live in discontent. |
| I have used a permanent magnet for face milling lots of times. It is very do'abel. A electro permanent magnet can be used for milling on 5 sides. The side towards the magnet has to have good contact. NO AIRGABs Regards Bent |
| What happens if you get a power cut to the electromagnet or a fuse blows? Big spinning things in contact with a (now not held) thin sheet of metal... just a thought!
__________________ I love deadlines- I like the whooshing sound they make as they fly by. |
| I would like to give you some info on this. Yes it is possible. We have 10 CNC finishing mills doing hard milling with magnetic tables. They are made by "SCHUNK". Their web site will have info on them. We use them because they can be milled flat to match the machine geometry exactly. We require this in the parts we make. They do have tremendous holding power. The parts do not fly off at power loss, in fact we disconnect the power after the magnet is enegized. The residual magnetism will hold the part for days or more. To remove the part, the power is reconnected, and the magnet controller performs a de-magnetization cycle. Never had a part move, even with some agressive cutting. Only thing I don't like about them is the steel chips and swarf stick to the magnet. |
| milling plate aluminum | eloid | DIY-CNC Router Table Machines | 12 | 02-08-2010 11:27 PM |
| Need Help!- milling 416 stainless plate | LexLuthier | General Metalwork Discussion | 1 | 05-14-2008 10:19 AM |
| Locating a part on a milling plate | stang5197 | General Metalwork Discussion | 3 | 10-10-2007 07:07 PM |
| Magnetic Chuck for Milling Machine...? | tdfsu | General Metal Working Machines | 8 | 03-19-2007 02:41 PM |
| Milling a plate square? | Blink- | General Metalwork Discussion | 12 | 11-14-2006 02:23 PM |
