Go Back   CNCzone.com-The Largest Machinist Community on the net! > Events, Product Announcements and More > CNCzone Club House
CNCzone Club House Discuss everything in between CNC. THIS IS NOT A TRASH BIN.
Old 03-23-2010, 12:46 PM
jallenmorris is on a distinguished road
Only non-ferrous metals???
In my research, I've seen the majority (actually all, but i'm leaving room for hope) of places say that you can engrave and work with non-ferrous metals. I'm learning so correct me if I'm wrong in saying that steel is ferrous, and therefore, you cannot/should not attempt to mill any steel parts with a cnc mill.
A blanket statement like I just made usually doesn't hold up in all situations. I am sure there are some that will say "If you want to mill metal, make a CNC mill, not a CNC router." Of course that's an oversimplified response to a not-as-simple question.
I, like so many others here, care about costs and if I can get a CNC router to do double duty, I will. What I love about DIY-ers is that most believe "If it can be done, then it should be done...at least once."
My questions:
1. What is it about most CNC router designs that prohibt their uses on non-ferrous metals? (Maybe it's more about the metal than the cnc design)
2. What would it take to make a CNC router that could do light applications on mild steel? I'm thinking of small sprockets out of material 1/8" or 1/4" thick.
I have come to my conclusion that steel + cnc router don't mix based upon the fact that I don't find much coverage of this one websites or in forums. If this was possible, I believe I would find much more information on it than presently available.
Could it really be as simple as use the right bit at slow RPM and slow IPM?
Old 03-23-2010, 12:54 PM
FYI for others that find this thread...
http://www.woodweb.com/knowledge_bas...NC_Router.html
What about aluminum? This is a non-ferrous metal right? I might be able to make the sprockets i'm thinking of out of aluminum.
What thickness is "too thick"? (Taking into account heat build-up, and anything else I can't currently think of.)
Old 03-23-2010, 04:21 PM
Typically a router is not built sturdy enough to machine most metals. When you build a machine capable of light milling, you have built a light duty MILLING machine.
Also, routers usually have speeds higher than mills. There probably is a cross over point where you could do slow routing and very light milling. Problem is, it won't do either very well.
Dick Z
DZASTR
Old 03-23-2010, 06:16 PM
ger21's Avatar
To cut steel you usually will need more rigidty and mass than a router has.
To cut steel you usually will need a lower rpm spindle than a router has.
To cut steel you usually need coolant, which doesn't get along well with the wood you'll also be cutting with a router.
Old 03-27-2010, 09:18 PM
MrWild is on a distinguished road
Add power to this also. It takes more power to push an axis and more power to spin the spindle to machine steel than aluminum. " " to machine aluminum than wood. So it takes a good bit more to do steel than wood.
Tags
cnc mill, cnc router, metal bit, non-ferrous
Need Help!- Best metals to use nenetwork Diemaking and Diecutting 4 10-19-2009 03:01 PM
Where do you buy your raw metals? dynosor General Metalwork Discussion 12 05-22-2008 02:02 AM
Need Help!- Thermocouples for hot metals navnav2006 Casting Metals 3 05-19-2008 10:27 AM
Are you casting metals? CNCadmin Casting Metals 17 12-08-2004 03:08 PM
Ferrous and Nonferrous Machine1 Hard and High Speed Machining 4 11-08-2003 07:31 AM
