Page 1 of 3 123 LastLast
Results 1 to 12 of 25
Thread: My next project....What a bargain.
    Gold Member MrBean's Avatar
    Oct 2003
    UK
    Talking My next project....What a bargain.
    I picked this up the other day after winning it on ebay for £10.50
    It is some kind of manually operated, negative scanning machine for digitizing photographic negatives.
    This is my knid of swag. It's loaded with goodies and ideal for CNC conversion.
    It's pretty much ready to go, as is. The linear motion hardware is nice and tight, but slides freely. All axis are chain and sprocket drive. I thought I'd have to replace these with belts, but they seem to have very little backlash. I've not measured it, but it feels like there's no slop at all. So I'll see how they work, before stripping them out for belts. I've stripped most of the stuff off that won't be required. This is much sturdier than my homemade CNC router will ever be. It even has a ballscrew to raise/lower the entire table and gantry, so you can have it at just the right working height. How thoughtfull.
    So the plan is..... To get some shafts poking out from the chain drive mech on all 3 axis, so that I can attach the steppers via HTD belts and pulleys and make some kind of table to replace the glass & lights.
    I have some steppers that should do the job already. I'm planning to put the PICStep drivers I built, in a purpose made box, so I can move the box between machines and just plug the motors in. (untill I build another set of PICSteps).
    So not too much work really. Some head scratching to do over how to get the shafts sticking out far enough to attach a pulley. I have some ideas tho'.
    I'll post pics/updates as I progress.
    Regards Terry.....
    Attached Thumbnails Attached Thumbnails My next project....What a bargain.-cnc-conv1.jpg   My next project....What a bargain.-cnc-conv2.jpg   My next project....What a bargain.-cnc-conv3.jpg   My next project....What a bargain.-cnc-conv4.jpg
    Gold Member Bloy2004's Avatar
    Oct 2003
    Sturgeon Bay, WI
    Geeesh Terry!
    What a treasure you got there for so little! ....and so close to you.
    ...hope your retrofitting goes easy!
    Bloy
    Oct 2003
    UK
    Actually I had to travel 130 miles to pick it up in the van. So add £25 in fuel. It's still a bargain.
    Terry.....
    Oct 2003
    Sturgeon Bay, WI
    Are those slides/bearings something like Thomson pillow blocks?
    Bloy
    P.S. 130 miles isn't far for something like that
    Dec 2003
    Quote Originally Posted by Bloy2004
    1UK mile = 10N.American miles
    Ask me how I know
    Al
    Oct 2003
    UK
    Yes they are made by Thompson. They are very, very nice units.
    Regards Terry.....
    Oct 2003
    UK
    Quote Originally Posted by Al_The_Man
    Ask me how I know
    Al
    Yeh. Your country is waaaay bigger. Anywhere in the UK would seem local to you guys.
    Regards Terry.....
    Jan 2005
    Missouri
    Congradulations, that is quite a find for being so cheap. It should be a breeze to convert, most of he hard work is already done. Almost makes me want to check out the photo labs around town.
    If it's not nailed down, it's mine.
    If I can pry it loose, it's not nailed down.
    Registered 10bulls's Avatar
    Feb 2005
    UK
    Wow! Fantastic! Bean haggling?
    Are those not steppers underneath the table connecting to the chain drive?
    I notice Mk I skulking in the background fearing the worst!
    Is it just me or do you have an urge to stand in front of it strumming the table and humming Toccata and Fugue in D minor?
    May 2004
    Terry, I think you misunderstood Al's comment about 1UK mile = 10N.American miles. I have been to the UK many times but other than London I have generally ended up somewhere around the Dover or Canterbury area (close to ferry or Eurotunnel). Last time I went over for the day (on a Saturday from Belgium) and decided for something different I'd go to Sandgate which in terms of distance (+/- 50 miles??) looked to me like about 30minutes away from where the Eurotunnel exits in England. Well 2.5hrs to get there, 4hrs to look around, 2.5hrs to get back, plus about 2hrs each way (drive + Eurotunnel) to/from Brussels added up to one long day. Mainly due to my ignorance I might add! Your machine looks like a great find.
    Skippy
    Oct 2003
    UK
    Quote Originally Posted by 10bulls
    The motors under the table are DC servos. They were for winding rolls of negatives across the table. The motors seem pretty weak tho'.
    The chain drive is connected to small hand wheels though an electromagnetic clutch thingy. It's very weak, not enough to hold the axis in position while routing. So I can't use the handwheel shafts to connect the steppers to. I have, however, managed to get long shafts exiting from the X & Y axis tho'. I'll post some pics later tonight. Z looked like the easy one to do, but it's turning out to be a head scratcher.
    I can imagine Mike Oldfield in my garage, playing the "light organ". Shame I have to remove those. They looked kind'a cool.
    Hmmmm. The Mk 1 machine will be dismantled once I've got the new one converted. I plan to beef it up some, as it's quite bendy. It's Ok if you take light cuts tho'. I may then give it to my farther, who has a small furniture making business.
    Regards Terry.....
    Gold Member High Seas's Avatar
    Sep 2003
    Malaysia/Australia/NZ/USA
    WHATA FIND! Will the light table become a vacuum table for piece hold-down? Or will you use/mod the negative spools/rollers for cutting endless length vinyl signage?
    Great SWAG! More pics and planning ideas! Jim
    Experience is the BEST Teacher. Is that why it usually arrives in a shower of sparks, flash of light, loud bang, a cloud of smoke, AND -- a BILL to pay? You usually get it -- just after you need it.
  • Page 1 of 3 123 LastLast
    1. Metal CNC Project
      By tonofsteel in forum General Metal Working Machines
      Last Post: 04-28-2005, 01:47 PM
    2. University Digital Electronics Class Project.
      By wholepair in forum Stepper Motors and Drives
      Last Post: 04-27-2005, 12:49 AM
    3. NanoMill project
      By chuckknigh in forum DIY CNC Router Table Machines
      Last Post: 03-18-2005, 03:14 PM
    4. Tiny CNC mill project
      Last Post: 11-19-2004, 02:00 PM
    5. Project a chain
      By HuFlungDung in forum OneCNC
      Last Post: 05-22-2003, 07:57 PM
