| CNC Wood Router Project Log Post your CNC machine building log here only. |
| Let's see If I can build this Router First of all a little about myself, I'm a Machinist Mate in the U.S. Navy and have been so for the last 17.5 yrs ( Title doesn't mean I'm an actual machinist but I get to turn a lot of wrenches and I work in some of the hottest enviroments on the ship ).I learned about this site from another DIY site. ( Lumenlab) another member of both sites directed me to this site. After lurking around CNC zone for a couple of months, learning what I can. I decided that my first router will follow Jrgo's plans. Over the last couple of days I've broken down , opened my very thin wallet and started getting the parts and some tools needed to build it. Here is a list of what I have so far.
And I'll keep you posted on my progress. it will be a while before I'm finished as I have other obligations. :frown: |
| Good luck and keep us posted. |
| Looking forward to seeing your progress. I made one and was in dout when I started too, but all worked out well. |
| Today friend of mine was cleaning out his garage and low and behold I now have all the bolts nuts and screws needed as per the JRGO plans All separated by size and pitch. |
| Today after work I went to the Norfolk Naval base's Wood Hobby Shop and used thier high powered and accurate table saw to cut all the pieces of MDF needed for this project; thus saving my sawblade. I can only wish my own table saw could cut as good.Question? Which is better glue for this project Gorilla or Tightbond? |
| Use the Gorilla brand glue. Follow the directions because it is a polyurathane type of glue. Use some latex or vinyl gloves on your hands, it is murder trying to get it off.
__________________ If it's not nailed down, it's mine. If I can pry it loose, it's not nailed down. |
| It sounds like you are off to a good start. Keep us updated with pics if you have a camera.
__________________ Mark -------------------------- Check Out My Build-Log(s): http://cnczone.com/forums/showthread.php?t=4716 CNC Router Version 1 [====================] 100% http://cnczone.com/forums/showthread.php?t=39294 CNC Router Version 2 [=|-----------------------] 5% |
| Yes pictures are required if you want our help ! Just joking ! but be all love to see what your doing and talk behind your back about the untidy workshop in the background !!! |
#10
| you may want to hold off on the glue until you dryfit everything and make sure it all lines up properly. |
#11
| I forgot to mention that it would be a good idea to use dowel pins on your glue joints. They will make the glue joint considerably stronger and will make dry fitting everything together a lot easier.
#12
| I was looking at using the glue this week end for the Base support structure, Bed support structure then the front and back support ( gluing two pieces of mdf together to give a 1.5" thickness). A friend of mine is letting me borrow his brad nailer and compressor to nail and glue all thoses small pieces the drawing requires. For those support structures in refference to drawing CNC DT106,107 of The Jrgo plans. |
| Now Hiring to build a 4'X4" router $500 + material costs-RFQ | midevilone | Employment Opportunity | 2 | 11-18-2008 08:21 PM |
| Want to build CNC Router for routing 3/4" MDF and solid wood | Darren_T | DIY-CNC Router Table Machines | 28 | 10-15-2006 09:31 PM |
| Want to Build a Wood Router | eqreservoir | CNC Wood Router Project Log | 3 | 02-12-2005 01:21 AM |
| New Router build and KCam Question | Pistachio | DIY-CNC Router Table Machines | 11 | 03-07-2004 07:55 PM |
