Results 1 to 4 of 4
Thread: looking for a solid design w/round linear rods
    Oct 2007
    Heys Guys/Gals,
    I need to build a Cnc machine for a project I'm working on. The thing is I need to build it with material that I have at my disposal so as to control the cost and not deter monies from main project.
    I have solid 1" round rods that I can cut from "exit door handles" and would like this to be the basis of the design for all three axis'.
    My question is; does anyone know of a good design that could use this material for a 25" x 25" (could be smaller; this the maximum cut I can get from the door handles) machine that will be used for mdf, engraving and PCB boards.
    I know the question is sort of vague but just to get conversation going as I have very limited experience in this area.
    Thanks folks.
    Ian
    Oct 2007
    Quote Originally Posted by SimSimmer View Post
    Heys Guys/Gals,
    Thanks folks.
    Ian
    Sorry guys this is in the wrong area. does anyone know how I can get this in the machine build forum? thanks.
    Sep 2009
    Checkout the JGRO or Joes 2006 CNC design on this forum. You will have to do some minor design/figuring out stuff to scale back the x axis to 25 inches..and some other things will change from using 1 inch rod instead of pipe...but it shouldn't be too bad. On the other hand, the cost of the pipe whether you use gas pipe or electrical conduit (as I am doing), is a very minor part of the cost, so if the redesign scares you at all, just go with the standard designs above.
    Oct 2007
    Thanks for the reply zeeway. I'll look into it.
  1. Newbie- linear rods versus linear rails
    By haylspa in forum Benchtop Machines
    Last Post: 08-11-2009, 09:44 PM
  2. Solid Carbon Fiber 15mm rods ?
    By twocik in forum General Metalwork Discussion
    Last Post: 01-28-2009, 05:17 AM
  3. Linear rods and linear brushings
    By Com in forum Linear and Rotary Motion
    Last Post: 06-28-2005, 06:48 AM
  4. linear slide rods for sale in the Netherlands
    By Tjippy in forum DIY CNC Router Table Machines
    Last Post: 12-06-2004, 02:46 PM
  5. How do Thomson linear rods work?
    By samualt in forum DIY CNC Router Table Machines
    Last Post: 09-01-2004, 08:52 AM
