Results 1 to 3 of 3
Thread: Building a 3 and 5 axis cnc milling machine/router.
    Aug 2009
    Exclamation Building a 3 and 5 axis cnc milling machine/router.
    Hello Everyone I just thought I should take this time to tell everyone about my new 3 axis cnc build. You can watch videos on the build at
    www.youtube.com/marcbrownvideos
    Also stay tuned for the 5 axis monster build. I have already started buying the materials needed to design this mammoth and will most likely start making videos this weekend. It will be 12ft long, 4ft wide, and the height is still being designed but will mostly be at a 7ft height.
    This is something you do not want to miss. As of right now I do not believe there are any 5 axis videos/homemade that actually show you the building process and in the end, it actually working.
    DO NOT MISS OUT ON THIS
    Remember
    Regards,
    Marc Brown
    Aug 2009
    First cut of the 3 axis machine using mach 3
    Aug 2009
    Part 1,2,3,4,5, and 6 of the build
  1. Building a CNC Milling Machine
    By leotech in forum Benchtop Machines
    Last Post: 10-15-2008, 05:04 PM
  2. Building and Open Source CNC Milling Machine
    By hesham morsy in forum Vertical Mill, Lathe Project Log
    Last Post: 09-23-2008, 03:13 PM
  3. Would you recommend building a CNC milling machine?
    By alexccmeister in forum General Metal Working Machines
    Last Post: 07-24-2008, 10:28 AM
  4. Heads Up - Article about building CNC Milling Machine
    By samualt in forum CNCzone Club House
    Last Post: 06-13-2005, 03:43 PM
  5. Building a 5-AXIS Router
    By Cnc Wana bee in forum General Metal Working Machines
    Last Post: 06-05-2005, 09:19 AM
